Round Jack Plugs
rotrax
17 Dec 2010
South Oxon and Littlehampton.
Hi, I know some on here are electrical whiz kids and are familiar with parts.
I need to run a remote charging lead for my Bluetti 180 Power Station. The supplied lead is barely 60cm long, I need 6-7 metres.
The supplied lead has a conventional looking round DC Jack Plug, but for an 8mm socket. I can only find 5,5mm ones. It needs to be rated for a max of 10 Amps.
Anyone have a source?
TIA. If I cant find one, I can, of course extend the old one, but would prefer not too.
Could it be a Hella or Bulgin type, or something like that?
That looks like 2 of those will be a cheaper easier solution than my Lumberg plug and making a custom cable as Farnell are expensive and the cable will need to be bought as well.
Thank you-that might well be the answer. I will need two, as the power station will be some distance from the most suitable charging source.
Appeciate all the help-this really is a useful forum!
How about cutting the lead and splicing in a longer new one, preserving the original connector?
That was the option could I not find anything suitable.
Thanks to Little Sister, post #6, It looks like I can get the ends and length I need.
Thanks guys-now I know they what they are called, thanks to the forum, thins will be easier in future.
Barrel connectors, AKA coaxial connectors, come in a bewildering array of sizes.
See Coaxial power connector - Wikipedia
You need to be sure that you know the size of the centre pin, which usually but not always, is the + connection. The way to measure that pin size is by using small twist drills in the center socket of the plug end until you find the one that fits.
One needs to think about that,
The extension cable may result in volts drop, or risk of overheating, depending on the output demands, also even with a new cable, size needs to be considered, and will the cable then actually fit the connector?
Got that covered. The ordered cable/connectors are rated at twice what I require.
Of course the extra length will result in some power loss, but not enough to be significant. Overheating should not be a problem.
