Round Britain day 43
Concerto
16 Jul 2014
Chatham Maritime Marina
Last night I checked that it was only 35 miles from Westray to Stromness. The tidal advice suggested it should take about 6½ to 7 hours. That seemed reasonable, hence not too early a start today.
Before I left I checked the 2nd and 3rd battens, they have both parted from cars as the car has a metal screw that was inserted into a plastic fitting. The loading has stripped the thread, so now I will think about a good temporary repair until I can get replacements. I also checked the bolts holding the arm under the tiller for the autopilot and found they needed tightening.
After slipping out of the marina I did a number of circles to reset the autopilot. It is now working perfectly and such a joy to have again. Feeling the wind I though I could start with a single reef in both sails. So I started this trip at about 8.30. Heading north to round the top of Westray was a reach, so I then hardened up on port tack. The wind was not where it was forecast to be and when I tacked I found I was about 15 degrees too low to clear the first headland. Oh well I will have to put a tack in and then overstand a bit to ensure I clear the next headland. This tack started to change course as the wind backed by about 35 degrees, This meant I had to sail even further out to ensure I could pass Noup Head. The photo below shows the track and my course approaching Noup Head. It is a very rocky point with a lighthouse above and I passed fairly close to it, not by choice.
Looking at the chart plotter it seemed I should be able to make the next section of cliffs and then I can crack the sheets, so I countinued on. Concerto was doing a pretty good speed of around 7 knots. I sat in the lee of the sprayhood and rested my eyes, then I sensed something was wrong as the genoa started shaking. The ram had come off the tiller arm, so quickly put it on standby and by this time Concerto had passed through the wind and backed the genoa. After freeing the sheet and settling her on the new course, I went to put the ram back on the tiller arm, only to find one of the fixing bolts had sheared. Back to had steering again.
Guess what. The wind backed even futher and increased in strength. What should have been a close fetch turns out to be a double reef on both sails in a force 7 again. So the next cliffs was a series of tacks but the rough water with rollers of 6 to 8ft meant it was difficult to sail too close to the wind. My tacking angles were poor at about 130 degrees as the tide was now against me as well. Eventually I clawed enough windward distance to keep clear of the lee shore with confused water. Then strangely the the wind started to veer back and instead of staying on a close fetch, it turned out to be a reach. Concerto was now sailing at 6½ to 7¼ knots through the water. The further down the west coast I headed the easier the wind became, but still stronger. I was now always above 7 knots and getting into the low 8's. For a period of over 5 minutes the speed never dropped below 8 knots. This was enjoyable sailing despite it being cold, overcast and visibility of about 1½ miles. So being further offshore for safety I could not see the coastline.
The closer I got to Scapa Flow, the bigger the rollers became and the higher the wind rose. I kept seeing 8.3, 8.4 then 8.5 before it slackened and then it went to 8.5, 8.6 and a peak of 8.8 knots. To be honest, this was getting silly, so I decide I would have to drop the main. So on went the Tiller Clutch to hold to course near to the wind so the main would drop, whilst tying the main on the boom, the genoa backed. Went back to the cockpit and found the outer sheath of the rope for the Tiller Clutch had broken and the clutch could not grip the rope any more. Super bummer. Not really a problem as it was a genoa reach towards the entrance to Scapa Flow. To check the entrance I tied the helm and tried zooming the chart plotter, and found the screen and my fingers were too wet to do anything. Nipped below for some kitchen paper, only fo find the boat had head up to wind and backed the genoa again. Dried the chart plotter and my fingers off, and the b....... thing still would not work. Keep swear to myself as I bring the boat back on to course. Tie the helm again and went for some more kitchen paper. My fingers still did not make the zoom work, but the paper did so that was sorted.
Heading towards the entrance looks nasty on the plotter, but with very big rollers, it looked very nasty. Oh well, here we go. Edging slowly towards the shoreline until I could make it out and then continuing south until I saw the other shoreline. Then I turned roughly eastward and the rollers were either square to the transom or a 45 degree angle off the starboard quarter. When these rollers met the breaking wave was spetacular to watch but not so much fun when it happened close by. These rollers could easily shift my course by up to 50 degrees and I was constantly using full rudder. I was sitting in the cockpit and decide I would see the shoreline better if I sat on the cockpit coaming and use the tiller extension. One wave broke on the transom but luckily did not come into the cockpit, another turned the boat violently and crashed on the port side deck and some slopped into the cockpit, then another even larger wave caused me to loose my balance and slipped back into the cockpit, where I was actually in a safer place. I have never seen such massive waves that were also very close together. Even under a double reefed genoa on a run, I was still doing between 5½ and 6½ knots, but the speed over the ground was only 2 to 3 knots. I had missed the tidal gate, so I plodded on with the violent movements of rolling slightly to windward and over to 30 of 35 degrees and the course swinging by 50 degrees either way. It WAS rough.
Slowly I hauled my way towards the narrowest section and the speed over the ground dropped to 1 to 2 knots. It was going to be a long slow rough end to the trip. When I was almost through I saw a welcoming party coming towards me. Someone ashore thought I was in difficulties, so the RNLI were sent out. I gave them a wave, but could not talk to them as my hand held VHF was below and I did not want to go below in those conditions. They motored alongside and they could see I was not having any difficulties, but stayed until I cleared the narrows and gybed towards Stromness. They then headed back to their berth. Tomorrow I will try and thank them for their concern, but I was quite happy in the conditions despite my breakages.
After rolling the genoa away, I set to fitting the fenders and warps. Then I went looking for a berth at about 8pm. The only one I could see was aft of a pair of rafted 40 odd footers, but a bow line was in the way. I then spotted a young lad coming off the outer Polish boat. He was on his mobile, but I shouted for him to remove the line so I could berth, which he did, then walked off to continue on the phone. I wanted to reverse back across the wind. Not easy, but eventaully I got the stern line attached to a cleat near the middle of where I wanted to be, but the bow blew off. I tried motoring using the warp as a spring, but it did not work. So I retied the bow line so one end was cleated. The bow had moved slightly closer to the pontoon as I had left it in a fairly high revs. At the third attempt I managed to loop the cleat at the end of the pontoon and pulled the bow in. Then it was a question of pulling and adding more warps to get Concerto alongside and moved aft. This must have taken about half an hour and when the young lad had finished his phone call and he came over to see if he could help, I just ignored him.
The boat was salty inside and out. I could easily deal with the outside, so got my hose out to wash all the canvas work and the whole of the deck. Whilst doing this I saw a large washer on the coachroof close to the mast. A quick check and I found it was from the gooseneck pin. The split pin holding it in place had partly broken away letting it drop. So just another simple job to fix. Tomorrow I will be washing down plots of the interior that got wet. I must fix those halyard slots as a matter of urgency.
Shortly after leaving Westray Marina.
Follow the dotted track from the boat and see the wind direction change on the other tack.
The solid line is the course and the boat shows the approach to Noup Head.
Approaching Noup Head.
Passing Noup Head.
See the tacking angle of about 130 degrees and how the courses vary.
For anyone wanting to read the reports from the start, this is the link to first one.
Round Britian day 1
Blueboatman
10 Jul 2005
Gosh you are going to know the boat so well and all it’s abilities ?
I’ve always found hard weather close to shore to be the toughest as one has to be so vigilant.
I hope you can fix the battens , I can’t envisage the design without a photo but perhaps (?) you could oversize them screw or melt the plastic hole to reform a thread or or or? I am guessing reallly
That’s a great write up , some fast scary sailing well accomplished , thank you ?
Supertramp
18 Jul 2020
Halifax
Gripping read. It's an area in which wind, tide and swell can create awesome conditions, which I think you found. We used to transit the firth E to W by going into Scapa Flow, resting (lots of good anchorages), then leaving South of Flotta and Longhope Island. Eynhallow Sound and Hoy Sound were often unpredictable when flowing West. Hope you find fixes for your breakages - they are weaknesses that will only appear when conditions get hard. I think I will find a spare gooseneck bolt to carry from now on.....
Cape Wrath next and that can be fun. Loch Eriboll is a good bolthole but beware williwaws. And the inshore eddy south of the Cape.
jaminb
7 Jan 2021
Sounds like a hairy passage - well done Concerto. By the time you are cruising along the south coast it will seam very tame without any thing left to break!
Neeves
20 Nov 2011
Sydney, Australia.
I have no idea what your battens are like - can you reverse them?
It can be so exciting making 8 knots and scary if you are making good speed but speed over the ground is so low - you worry about getting anywhere.
Good account, well sailed.
Jonathan
srm
16 May 2004
Azores, Terceira.
Good to hear that you got in through Hoy Mouth against the tide; you were very fortunate that it was neaps. That is an area I have seen in all weathers and have the greatest respect for, to the extent of having sailed slowly on passage from Cape Wrath or heaving too for a couple of hours well off so as to enter the sound with the tide and a comfortable ride.
If leaving for the west its more comfortable to go out with the very last of the west going stream/short slack water to avoid the Atlantic waves against tide that you experienced coming in. Once clear of Orkney the tide stream is weak if you keep well off the north coast and you should then carry a favourable tide around Cape Wrath. Cape Wrath can also give severe wave against tide conditions. I always aimed to pass three miles off to avoid the rough water, but could then cut the corner if the sea conditions looked reasonable.
srm
16 May 2004
Azores, Terceira.
Battens: My batten cars are no doubt different to yours. However when one connection failed out in the Atlantic I simply drilled a hole through the plastic body and the batten (with an appropriate curvature in the sail) and fastened with a short machine screw washers and nut. When another batten suffered the same problem I used the same fix. Some years later and they are still there. Just have to undo the screws when removing the sail. May give you an idea for yours.
Concerto
16 Jul 2014
Had a long chat with my sailmaker this morning. He was very surprised that the threads in the plastic had stripped. He is going to check with his boss to see if this has happened with any other customers. I will take some close up photos this afternoon as the sailmaker would like to see them. He also suggested checking the 1st and 4th batten for damage.
The discussion turned to a temporary repair and he liked my idea of using a Dremel to clean the inside of the hole, followed by using a needle file to cut some grooves. The metal screw with be lightly covered with some grease and then epoxied back in place. This should allow the screw to be removed in the future. Once I have the part number they will send 2 new ones to my daughter, who I shall see in about 6 weeks time.
I shall see if there is sufficient material for a side bolt to be fitted as an extra precaution against movement as this will act as a clamp.
michael_w
8 Oct 2005
I swear by a chamois leather for drying anything. Has the great advantage of never running out of the ability to dry when compared to a cloth towel.
ProDave
5 Sep 2010
Alness / Black Isle Northern Scottish Highlands.
I am reading this thread with great interest.
The last few passages have confirmed my view that we are having an unusually windy start to the season this year. I take my hat off to you for pushing on in what many of us consider foul weather.
I am probably in the category of a fair weather mostly day sailor, and so far this year, I have been dismayed by the amount of strong wind we have been having, Far more so than I can remember in previous years. It is s shame much of your time in the north has been such and you have not been able to properly appreciate the area.
srm
16 May 2004
Azores, Terceira.
Cannot wait to get to Lake Solent. I have heard they sometimes get some waves half a metre high.
Only sailed there once, for a few days during a November for my YM exam. It was nice and relaxing after a summer season around Shetland. Something for you to look forward to.
As @ProDave said, you have been really unfortunate with the weather - its not always that bad and about one summer in four can be magical. One summer we set out from Shetland for the Western Isles, but got no further than Orkney due to high pressure and light winds. Instead we enjoyed drifted around the Orkney Islands, mostly in sunshine, using the tide and light airs for a couple of weeks.
Blueboatman
10 Jul 2005
You are definitely on the case ?
We are I think all really enjoying and rooting for Concerto and the northern Atlantic ‘baptism’
I suppose one might say you’ve done the wind section of the Concerto !
Do you have a really deep reef for just jilling along when you need to mark time or ease up a bit? I can’t recall having seen a photo of one..
SaltyC
15 Feb 2020
Yorkshire
Concerto, the North may have challenges but after many years away I agreed to skipper a boat for Blind Week. I am unable to attach a photo of Yarmouth harbour yesterday, (file too large) stern to berthing on a long pontoon, £45 a night for 36'. Give me the peace of Scotland anytime.
Concerto
16 Jul 2014
No, I only have 2 reefs as I never planned to be out in over a force 7. Perhaps I was wrong, but Concerto is still handling perfectly well despite this.
Concerto
16 Jul 2014
After my post of this morning I spent part of the afternoon fixing some bits.
From my stock of bolts I found a couple of bolts the right size and length but countersunk rather than pan head. These have now replaced both old bolts as a temporary measure until I can buy some pan head ones.
The line for the Tiller Clutch proved slightly more of a problem. I checked the rope size and thought I had some that matched, so I cut it to length, sealed and whipped the ends. Only to find it was fractionally to large. So I unscrewed the clutch from the tiller and took it below to see if I could make it fit, but no it just would not fit even with a whipping twine line to pull it through. Burrowing in my stock of small ropes, I found another line that was smaller, that fitted and worked in the clutch. This has now been fitted but I am not sure how strong it is, so again only a temporary fix as I doubt it would be strong enough for yesterday's conditions.
What I am surprised by is no one has commented on the time I posted the intial report. I did need a little time to unwind and relax, plus write up the day.
Attatched are some photos of the offending batten car so you know exactly what I am talking about.
Stromness Marina. Concerto is on the extreme left.
My welcoming committee boat.
Nothing but the best for Concerto!
The sheered bolt from the autopilot arm.
The shredded line from the Tiller Clutch, just visible on the tiller.
The problem with the batten car.
What it should look like.
The other side.
The screw that is held in the plastic.
This is the stripped hole that should hold the bolt.
