Rope diameters
OceanSprint
23 Oct 2012
I need to replace my haliyards and sheets. After many internet disasters I am really nervous of ordering stuff as I have frequently got the sizes wrong. And I have no chandlers near where I live.
I know this is a lame question. But is there an easy fool proof way of measuring rope diameter ? It squishes up so hard to be absolutely sure of a measurement.
If you had subscribed to YM back in the '70s or so you would have received for free a little plastic gadget/gauge which would have allowed you to make the measurement. Most lines have at least some part which is uncompressed and usable for measuring.
I know what you mean, a lot of modern rope is prone to flattening when you measure it.
Sometimes it's easier to measure the circumference and divide by 3 and a bit.
A tip for the future. I have kept short lengths of common sizes, (50-100mm) fixed to a small piece of board and labelled. Easy to put this alongside what you need to identify.
drill set and a block of wood?
does the rope fit?
a bit like this... but for rope!
I lay an unstretched part of the rope on a steel ruler at the 10mm mark (or above to get the simple markings) then looking from above line up one side as best I can. Then just read off the scale and deduct 10.
Not fool proof but near enough.
