nimbusgb
I am using a good quality furling line about 8mm, perhaps 10. 1 season ol and stored away when not on the boat so its pristine. Drum is just about full when fully open so best leverage available.
Yes how you unfurl does make a difference if the line is uncontrolled it tends to lock itself up when furling ( or trying to ) because with the soft wind on the high tension required to furl buries the rope under previous turns so I have to be careful to keep tension on when unfurling.
As to the diverter the halyard does go in at about 15 degrees to the swivel so that looks OK anyway.
I'll take the turn block and camcleat out of the equation by just coming straight to a winch, not for the power just as an alternative to pull on. That is a new turnblock, a spinlock metal sheaved one so it SHOULD be a good quality but ........
Haven't had much time to tamper with it today, been chasing the winter cover and removed and rewired the windlass ...... now I can pay out chain and wind it in from the cockpit! fancy me hey!
Just why Beneteau fitted a reversible windlass and then hobbled it so that it would only run one way beats me!
