suebabsthenoo
Active Member
Hi we are brand new liveaboarders.We have a Nautiacat 44.Anyone know how to rig this sail it is of the hank on variety?
No, it is not hanked on the beading goes into the slot on the metal rod. It is quite a big sail and if it is your first time it would make sense to get some help from a neighbour who has done it before to show you how to get the tension right.Hi we are brand new liveaboarders.We have a Nautiacat 44.Anyone know how to rig this sail it is of the hank on variety?
If the kit has not been serviced for a while you need to wash and grease it all before putting the sail up otherwise it will not work well. It is a big sail and you will find it hard to furl. Before you let the sail out in any wind at all make sure you have some kind of winch to help you bring it in again with the furling line. You might have one on the stern, or you can use a primary winch if you have to. The forces can be fairly high. If it is your first time it is worth getting someone to help for half an hour or so. The system is no different from any other similar furling system it is only that the forces are a lot bigger if there is any wind. Nice yacht. It will serve you well and great for a liveaboard.How do you hoist it is the question I am brand new boyriend is not but boat v complictad to what he is used to.
'onest guv it is a hank on and there is no foil, the sail(inner foresail) we have put on is in a foil that was easyish .It was all taken down in a rush when boat stored for winter.There seems to be no halyard for it.Thanks for reply as well x 2As in my post above in which I tried to give step by step instructions from start to finish.
In summary - attach halyard and sail to the swivel - feed luff tape into slot in the foil as you hoist it by pulling on the halyard. Tension halyard tight with winch.
If I have not given you sufficient information (which is difficult without pictures)suggest you ask around your yard / marina for someone who can help and identify the parts on your particular boat. However, big or small, they are all the same in principal.
As you are new to all this I would suggest a week's practical course with a cruising school - they won't have the same boat, but there is not much difference between boats once you know the basic principles. Some boats are just bigger and heavier, like yours, and will have bigger and heavier gear which may look a little different, thats all.
Good luck.
The prob is finding the means to hoist it, all it has is a swivel pulley at the top of the forestay with a length of wire which i the same length as the forestay,all was ok wen sails taken down in OctNeed more info - is the problem reaching the end of the bowsprit or trying to fit a sail with hanks to a roller furling gear?
Are you also new to sailing by any chance?
You said that it was a 'Roller furling bowsprit genoa'. How can you furl a genoa if it is hanked on? I've never come across such a thing and I can't see how it can work.'onest guv it is a hank on and there is no foil, the sail(inner foresail) we have put on is in a foil that was easyish .It was all taken down in a rush when boat stored for winter.There seems to be no halyard for it.Thanks for reply as well x 2
Sorry to carry on with this but I still don't understand. A hank is a clip, with clearance. The forestay is a wire. If you hank the sail onto the forestay the sail can be hoisted up and down no problem. How do you get the sail to roll around itself? Somehow the thing that is rolling the sail up must be attached to the sail. If not by a beading in a slot in a foil then by something comparable?The sail does nae go into a foil it is hanked on to the forestay which has a drum as in roller reefing with which to furl it (as Nigel Calder in his book says)is strictly a furling rig to be used only when sail is luffing,we now think there is a halyard missing somehow since packin boat up in Oct and getting it out of packing in July.
