NormanS
I would develop a system that doesn't involve anyone's hands coming in contact with the chain. For instance, I have a slotted chain stopper on a short strop, which removes the need to take turns round a post, and also the need to lift the chain off the gypsy. The chain is pressed down into the slot with the sole of my shoe.Lots of food for thought.
Generally we try to get the anchor right first time. Having a very slow manual windlass encourages that!
So we aim to have it touch the bottom whimsy we are not moving, and then if the conditions are light I will feed the chain out through the hawse hole hand over hand to match the died that we are drifting back. In stronger conditions I'll use the brake on the windlass instead. I don't like to let us build up too much speed, since once I apply the brake there's a big load on the windlass.
Having veered a minimum 3:1, I'll then take a few turns around the samson post and gently take up the strain in astern, before applying around 2000rpm for a couple of minutes.
Next, I'll tie on the snubber and then veer additional chain until the load is on the snubber and the chain has a big bight of slack.
Any thoughts on my technique would be appreciated. It works 99% of the time, but in the last few weeks we've had horrible squalls touching 50kts and as I am explained above the Rocna has finally proven itself to be less than bulletproof.
A huge contribution to technique is to use a fishfinder to ensure that the anchor goes onto a clear bit of ground. That's a couple of suggestions.
