Rocna Anchors acquired by Canada Metal Pacific
Is a slightly bent anchor really useless?
Perhaps this may answer your question, it was certainly most important to Smith in this email from him re testing.
I have removed much of the middle of this email ( is is available somewhere else on this site in full if you want to find it) but note the bold underlined portion at the bottom.
Sent: Sunday, 20 September 2009 9:00 p.m.
To: Tanya Le Fleming Burrow; Steve Bambury
Cc: Grant King; kiwiroasmith@rocna.com
Subject: RE: Problems with Rocna?
Peter has replied re your queries #1 and #3 below, here is response re methodology for testing.
Firstly once again I reiterate that we were always paranoid about testing, and distributors which were our contacts (Rosch, Boyd, Denrex, SCM) years ago were told not to supply anchors upon request unless with our approval. This is just part of normal relations with the all-important distributors, who are entirely responsible for marketing the product (especially in foreign language regions) in their area. However they are not the experts, and your instructions to them should be no more complex than “don’t provide anchors for tests without our approval”................................................................................If HF have any say in a magazine running a test program/article, insist on seeing the test design and their methodology. Also examine previous tests if available. Nb. this isn’t always the entire picture; the German test doesn’t actually explain details of their methodology. If they won't cooperate, tell them to you are not interested and refuse permission to feature the Rocna. It’s just not worth it.
They are often receptive to some input and advice to create and report a level playing field, just don't know how to.
West liaised with me before running their last tests, even if they did deviate from the plan when half the test anchors would not set when testing on the “edge” as I suggested. We also provided the test Rocna anchor, air freight from NZ.
If you know a test is to be run it is best to provide the anchor (sponsor). This way you can provide a tuned anchor you know is correct in every aspect, especially the correct tip shape and sharpness which is critical for immediate good test results. A number of tuned 10s and 15s, as well as Stowables, should be kept in stock for these occasions. Don’t send a RRR, even if there is a market for the small sizes, the slots on the SARCA and Supremes are universally criticized and receive negative publicity.
Some factors to be considered in any test design:
1. A realistic environment for which general purpose anchors are designed. Not frozen beaches (Starzinger / Practical Sailor), solid rock, dry substrate, etc. Be wary of weed/grass also, it’s extremely difficult to get consistent results and although Rocna should still out-perform, the need for multiple trials would be all the more. Also a broad range of bottom types is essential to weed out the specialist anchors such as Fortress. E.g., sand, mud (hard and soft), clay, sand/mud and stone-shell-molluscs-weed combination, sand/mud and weed, kelp, dead coral debris and a stone/rock combination.
2. Multiple trials in a cyclical set-up (not anchor A trial 1-2-3 anchor B trial 1-2-3, but anchor A trial 1, anchor B trial 1, A-2, B-2, A-3, B-3, etc) to reduce environment “drift” – it’s a hassle to swap anchor and shackle continuously so there is resistance to doing this properly. Ideally the test vehicle should be held stationary over the same bottom for each cycle, maybe between a marked out lane.
3. Willingness to reject obvious aberrations such as a result that a anchor performs better at shorter scope or other impossibilities; data needs more analysis and averaging.
4. Control over environment. Difficult to find consistent bottom in large area at constant depth. See 1 and 2 above.
5. Testing of setting performance, e.g. measure of distance to set and consistency. This needs to be observed in shallow water or with a good dive team. More emphasis should be given to the “quick set” feature, a major advantage of a modern anchor.
6. Test of ultimate holding power, not some abstract low level limit which almost all the test samples will attain.
7. Control over pulls, need to use twin screw heavy powerful boat for even and measured force application, not a small yacht “because it's realistic”.
8. Constant rode at realistic make-up and scope(s). I don’t like rope and chain combinations for testing, there is too much spring created by the anchor as the bottom is very rarely even in consistency. Wire would be better but harder to handle. All chain would be okay as at load it will be straight, so scope ceases to be a consideration, or use lighter chain. It is a constant over all the anchors anyway and the results will be much easier to analyze.
9. Control over set time, set quality improves over time, this must be constant. Set then leave 5 mins under identical conditions then pull, or whatever. I like to see a series of light pulls between no throttle before consistent high load applied to give more realistic results.
10. Fair treatment of “old friends”, e.g. West Marine/SAIL gave way more attention to CQR than was fair because they were so surprised it failed to work. A new unknown would have been written off straight away.
11. No commercial bias, especially in small markets. Look for brands/manufacturers local to the magazine? Are there big spenders w.r.t advertising? Are they touting for ads placed in context with the write-up? Old boys’ network? Typical in NZ and Aus magazines and probably other smaller.
12. Analysis of results:
• Fair weight-for-weight comparison, e.g. Rocna 15 is 33 lb, closest Supreme is 36 lb = 10% difference which they typically won’t account for.
• Results should be “normalised” on a weight-for-weight basis.
• Watch for them asking for the “manufacturer’s recommended size”, otherwise you get rubbish like a 20 kg Rocna compared to a 10 kg Delta.
• No direct comparison of mixed metal types (steel / alloy is typical problem), apples/oranges. Both the alloy Fortress and the alloy Spade are notorious for this one and is the fault of the testers’ lack of understanding.
• Record sensible numbers (holding power is the max force the anchor sustains up to and before it moves – this seems a hard concept for magazines to get their heads around).
• How is a failure to set analyzed? – “infinite” set distance = difficult to graph.
To repeat: If they ask for an anchor and you decide to provide, then make 100% sure it is perfect. Check symmetry, shank straightness, fluke sharpness (sharper is better for test, they don't test longevity/durability!), etc.
As to the German “test”, the results are bizarre and their analysis not consistent with their own graph, but I can’t provide any answers until I see the test anchor. However, we have told you repeatedly that the Chinese anchors that you are shipping are NOT to spec, and we have yet to see one that is acceptable. I assume the anchor that the Germans tested suffers from the same problems. It should not have been provided; rather, send them a tuned sample ex CNC.
Trust this is what you are looking for and is of some help,
Regards Peter Smith.
Or perhaps this email from Smith:
Note the bold underlined again:
Mr Brian Bambury,
Managing Director,
Holdfast Anchors Ltd.
Dear Brian, Grant, Steve and the Hold Fast crew,
Craig had the chance in early November to inspect a recent delivery of Chinese cast Rocnas at Absolute Marine on my behalf and forwarded a report backed up with some photos to illustrate points he made. I am disturbed by the report as a sample of only two anchors (a 4 and a 33) displayed numerous faults which would appear to be indicative of general poor quality and non-adherence to specifications across the range.
There has been a continuous dialog over quality and adherence to specification over the last year in particular with Grant as the Chinese anchors have come onto the market, with undertakings that the issues are in hand and that no further out of spec anchors would enter the market. It would appear from this brief report that this is not the case and as indicated from your Q3 09 royalty report, a substantial number of anchors have been returned for repair or refund from distributors indicating a problem of some sizeable proportion.
Not only are these anchors out of specification in various areas, the quality of these anchors is destroying (or has destroyed) Rocna's reputation for a quality top end SHHP anchor. Pricing is still at the very high end with the result that new distributors are not coming on board, market share is not increasing, and anchor sales are flat-lining or dropping, which is reflected in royalty payments.
Instead of concentrating on systemic problems within Hold Fast regarding quality, costing, and the absence of suitable in-house capability, Steve appears to embark on wild goose chases and continually misidentify challenges (or deflect responsibility); for example by recently suggesting the "Ultra", a stainless-only Spade knock off which would have a production cost two or three times that of Rocna, is naturally out-selling the Rocna because the Rocna design is inherently uncompetitive. He does not appear to consider that the US and Australian distributors of the Ultra appear to be fairly good at their marketing, that the product is reasonably priced (for what it is), and that in light of the incompetence of the genuine Spade manufacturer it is well positioned outside of Europe to take advantage of the effective absence and over-priced nature of the Spade (the parallel with Hold Fast and Manson should be obvious). Meanwhile, in this suggestion from Steve, the real threats of the Manson Supreme and Delta appear to have been totally forgotten: the one illegally injuring Hold Fast with a cheap knock-off and the other with the world's most popular anchor, both very comparable in manufacturing requirements to the Rocna but nonetheless efficiently produced and shipped at significantly lower pricing by the respective companies.
Beer can openers and scaled toy anchors are successfully produced while even minor changes to the design as instructed (the trivial alteration to the shank of the 20) are not completed, the Stowable is disregarded and left to languish despite clear and obvious market demand, which will almost certainly be filled by a competitor sooner rather than later. The simple modifications to the 2D cut profile for the shank of the RRR have taken the best part of a year to be processed yet nonetheless the result is a on going cock-up.
Steve is correct on one point how ever when he says sales affect my income as licence holder, and this is now a major concern to me as I would expect that sales should now be reflecting Rocna's potential as the top SHHP anchor in the market, the minimum sales clause in the Agreement notwithstanding.
At this point I would remind you I recently offered Hold Fast a PR coup on a plate with the introduction of two of the world's most renowned offshore sailors, both of whom are still very much in the public eye and who were agreeable to using Rocnas on their boats. I still have had no answer from Hold Fast to my e-mails on this matter. One if not both opportunities has now been missed. Reflect on how much the Rocna 110 on Steve Dashew's "Wind Horse" has been worth to Rocna in terms of credibility and sales. Meanwhile routine customer enquires are not being adequately handled, with the occasional client e-mailing Craig directly for answers to simple questions after receiving no response from enquiries@rocna.com.
Following are my comments and suggestions on the report which may be of some assistance but are made with out prejudice as I reserve my final judgment until I can inspect anchors in person.
I have asked Craig to forward to you his report and photos for your information and comment in return.
1) The packaging of these anchors is a major contributor to galvanizing and hence visual damage. Bubble wrap will not stop the damage reported. In the early days I was using scrap cardboard wrapped and taped around the vulnerable areas (roll-bar extremities, the fluke underside step apex, and the tip). It would appear this is still the best solution considering that scrap cardboard is free and Chinese labour not a significant cost issue, followed by bubble wrap. Note that any cardboard must be dry and kept dry , not wet as per the anchors shipped from Wormington Industries with the resulting complaints of Galv. quality and damage.
2) The Rocna 4 is weighed at 5 kg (subject to bathroom scale errors at that range). If correct this is 25% over-weight. The designed mass with the larger roll-bar of 21.3 x 3.2 mm is 4.1 kg. With the correct roll-bar as below the weight is 4 kg.
3) The roll-bar is measured at 23 mm OD x 3 mm wall. This is too large; however it may be the pipe has deformed and is not fully round. This needs to be checked and confirmed. Please note:
The 4 and 6 were designed with roll-bars of 17.2 mm OD x 2.9 mm wall, to BS 1387 with a grade of between 320 and 450 MPa. 21.3 x 3.2 was used in NZ by CNC because of trouble sourcing the correct pipe. The 17.2 x 2.9 would be much more appropriate and will be available in China.
Could Grant comment and I will confirm the specification for him if this does not create a problem. Note this does not address the extra weight observed.
4) Both the 4 and 33 are longer by 7 mm and 8 mm than designed respectively. This would be the case if the tips are not ground correctly into the chisel tip shape but are left sharp as per the cut files for the plate anchors.
Craig reports they are indeed still too sharp.
Do the moulds have the chisel tip shape or is this ground after casting?
5) The #4 shank being off-center needs no comment. It is unusable and is a reject. Any anchors with this problem are "unfit for purpose" in terms of the Consumer Act. There is no tolerance for this in the specs. The Chinese need to ensure their jigs are exact and fool-proof in this respect.
6) The shackle slot on the 33 shank end is 52 x 20 mm. It should measure 50 x 18. It means the material left around the shank end is not adequate as the anchor shank design has been refined to a minimum in this area.
7) The skid to blade apex must be properly radiused as was discussed in detail with Michael and in numerous E mails since including the quality control list Mark Pocket took to China. This has a function in the skids action when the anchor is setting. The inside apex must be filleted to compensate.
8) The toe to heel underside apex should be filleted, this relieves the hard spot and would help with distortion.
7) I will not comment on the report's reference to blade distortion in various planes. They are well outside specified tolerances; is not acceptable and needs addressing. If distortion is not symmetrical over the blades either side, which appears the case, it could cause cork-screwing in actual use. Witness the recent mysterious failure in soft mud written up by a certain German magazine. These anchors need to be rejected and pulled from the market.
8) As well as not conforming to specification, the uneven and wavy blade edges degrade the product and help reinforce the perception of "cheap Chinese casting". Ditto as to shank, blade edge and shackle slot chamfering. Ditto surface finish, which appears to have degraded compared to previous prototypes examined.
I look forward to some assurance by return as to how these issues are being handled.
Yours faithfully,
Peter Smith.
And finally this extract direct from the manufacturing specifications re shanks:
• Shank must be straight in both planes on assembly. Profile cutting heavier plates can sometimes causes the shanks to bend and need straightening.
• The sheet plate steel as delivered may also have a manufacturing bend. The shanks must be nested on this plate in such a way that the bend is minimized.
Bends of more than 1mm per 500mm must be pressed straight.
An anchor was bought in France in mid 2009. It was one of 844 anchors shipped, primarily, to Europe (some went to NZ). The 25kg anchor, size recommended by Rocna, in question was in use in the Bahamas and bent. The anchor was not caught on anything on the seabed, there was no damage to the yacht. The anchor was replaced (by Rocna) via Suncoast in the summer of 2010. The replacement was a 33kg model. To put in context our yacht is slightly smaller, by 2' than the one 'described', we use a 16kg anchor. We cruise to Tasmania's west coast, commonly experience 30/35 knots at anchor (its the nature of Tasmania) - would not give it up! Our anchor has not bent.
I arranged for the bent anchor to be independently tested it has a yield strength of 357, the min for Bis80 is 690, typical is 750. The replacement anchor has also bent, at the shackle point. It was also independently tested. The 33kg model has a Ultimate Tensile Strength of 530 (the min for Bis 80 is 790, the typical 830). (We tested the 25kg to destruction but only conducted Brinell on the 33kg model.)
To me it is totally unacceptable for an anchor to bend under conditions to be experienced under weather alone by a yachtsmen. If it bends when jammed in rock or coral I might accept that the owner has some measure, probably a lot, of responsibility. But to bend as a result of weather, the 25kg model, or normal usage, the 33kg model - is totally unacceptable.
The fact an owner might have an adequate second anchor is irrelevant, second anchors are carried in case of physically loss of an anchor, needs to use two anchor, needs to lend one out - the second anchor is not there because an anchor maker is dishonest, corrupt or stupid (and all three etc).
The fact it might or might not re-set is, currently, academic. Anchors should not bend under conditions that any yachtsmen might sensibly encounter.
If we carry this to its logical conclusion we all need, 2 engines, 2 masts (is this an argument for catamarans?).
There are 300 of these anchors in the UK plus another 100 delivered in the second half of 2009 (plus the 50 to which the chandlers admit are out of spec delivered in 2010). There are hundreds of these anchors across Europe, some owned by British yacht owners.
If the two anchors tested are representative - we have the potential of hundreds of bent anchors.
Jonathan
Neeves
Wow, you sure can expand on this topic.:eek:
I do not disagree fundamentally with what you say, but it is the magnitude and revelation of this problem that I cannot agree with.
The facts are:-
1. There are anchors out there that may bend. How many and under what circumstances cannot be exactly defined.
2. If it does bend no one knows if that will cause it to release from the sea bed, or indeed if that releasing is any more likely than any other anchor so it is not possible to define exactly whether there is a safety problem or not.
3. If you have a bendy one the new manufacturers will replace it.
4. If you think you have a bendy one the new manuacturers will probably replace it.
So, apart from the fact that some of the people who were involved in the process, but no longer are, may have been economical with the truth, this whole topic is punching way above its weight IMHO.
The facts are:-
Its all very well saying the manufacturer can replace it - but if you are, lets say in Greece, where will you get one. As you have no anchor you may need to go to a marina - which will cost you money. Why risk it in buying one now when Manson etc all provide a tested resource from an HONEST supplier.
I suspect that you are trying to justify your decision to have another Rocna.
I know two liveaboards in Greece who have bent the shanks of Fortress anchors. For the reasons you give they were unable to take advantage of the replacement offer. They bent them straight again.
The facts are:-
1 The Shanghai factory said in Dec 2008 they were going to make 844 anchors from a 420 steel in the shank, in the event some of those anchors are a '400' grade. Peter Smith said there were 700 made in 2010 with a 420 shank. Between the 844 and 700 a further 500 were shipped, second half 2009. The numbers seem pretty clear. 844 + 500 + 700 = 2044, 450 of these anchors came to the UK, of which the importers/chandlers only accept 50 as being out of spec. Tests show the 400/420 anchors bend easily, see my earlier post today of real life and academic testing yesterday.
Maybe, for you, 450 anchors out of spec anchors in the UK is not large, and the fact that 400 of them are not acknowledged is not important (unless you unwittingly own one)
2 No-one has come up with any evidence that Supremes or Excels bend, yet Rocnas do. Supremes, Rocnas and Excels were all designed to use Bis 80. The only ones with a history of bending are Rocnas, based on a 420/400 steel. I think, and this is a personal comment, that most people assume brand name anchors will not bend under correct usage, especially when they have been so hyped (best in WM tests, RINA cert etc etc). A Bendy anchor seems a contradiction, its a bit like a leaking liferaft, or a British 'summer'!
3 CMP and Rocna have never advertised they will replace a 2009 bought Chinese anchor. They have issued no warning that these are built from below spec.
4 Its a bit late to know that ones anchor might be replaced when you are sitting with it, and its bent, on your foredeck and the forecast is such that it would be stupid to sail to that chandler 100nm away (and your second anchor is a smaller version of the first (after all you bought it as being 'rock solid' etc etc (and you do not read this thread!)
Jonathan
Jonathan
I am going to post my final ever comments on this topic so feel free to have the last word if you like. :D
The fundamental situation is that
1. There are some weak anchors.
2. The supplier is not going to issue a recall
3. Anyone who bends one will get a replacment if they push for one.
4. Anyone who wants a replacement will probably get one even if they dont bend it.
5. No matter how much journalists go on about this not a lot more is going to happen.
In my view if Craig hadnt stuck his foot in his mouth so often, and if there hadnt been an issue between Grant and his old employers this whole thing would have been old news ages ago.
There are a lot bigger problems in the boating industry than anchors that might bend, which might be a problem but might not.
1.There are some week anchors - understatement of the year.
2. Get a replacement - you just don't get it do you
SO you are happy rogues get away with it are you.
Glad I don't know you
Sorry, this is personal so I just have to have another last word.
Yes, "some" anchors. "Some" does not denote quantity. It just means "not all" so is true. Nothing more meant. If you add your own incorrect interpretation to my words you are effectively arguing with yourself!
Getting a replacement may be inconvenient and costly. Thats life. I get it perfectly. Many things are inconvenient but bleating about them will not fix the problem. It wasn't easy for me to get my replacement, but if you deal civilly with the supplier they can help. CMP actually paid for the carriage both ways for my anchor i.e. to ship a new one to me and ship the old one back. 180 miles each way for a 33kg anchor.
I am not happy that people get away with things. I have made no comment on that and if you bother to read my other posts you will see that I specifically say that I will not comment on this.
I am however a realist and the point of my post was simply to say that there is no point going on about this as nothing is going to happen. You may not like that, but if one day you prove me wrong I shall congratulate you.
Lets try to avoid the personal comments shall we?:rolleyes:
I am however a realist and the point of my post was simply to say that there is no point going on about this as nothing is going to happen. :
Quite a lot has happened already. Holdfast, which seemed totally with scruples, has gone out of business. The new licensee has undertaken to replace faulty and suspected-faulty kit (although you have to ask nicely first).
Both of those things seem to have happened as a result of public pressure here and elsewhere. I suspect if the pressure is maintained, we might trigger a full recall, which is what the situation requires if CMP/Rocna is to regain credibility.
Twister,
I'm with you on this one.
Two anchors bought in early 2011 are to be tested in the UK. These both appear to come from shipments from China arriving January-ish 2011. There has been no mention, yet, of a shipment made from China after the June 2010 arrival (the 50, part of Peter Smith's 700 that he and the UK chandlers admit is out of spec). On the assumption these turn out to be 620 models this would limit the out of spec 420 models in the UK to 450 units and sold between early 2009 and Dec 2010. Mind you one needs to add the ones that went to Europe, 500/600 'down under' - or in the antipodes.
There is to be a series of tests of late 2009 anchors elsewhere in the world (and hopefully people in the UK will be encouraged to join in) - which will be news to gladden CMP's heart.
But Ex SolentBoy, If there are other things 'wrong' with the boating industry I'm receptive. Forget financial woes, stick with techniocal issues. I suspect others might be interested and you might enjoy considerable support - too many sit on the sidelines hoping issues will go away, or it will not happen to them.
Sticking with anchors but broadening it a bit - it is most odd that anchors can be sold in chandlers, admitedly often as cheap as chips (with a notable exception), and they need not have any specification and/or they do not need to be tested - yet authorities demand them as a safety item. Its equally odd that even though Holdfast was exposed there is little that marine bureaucracy could do about it - in fact whatever that bureaucaracy is/was it never even lifted its head above the horizon.
The same goes for chain, some is tested - but there is a lot out there untested and there are some manufacturers whose attention to safety issues might be questioned.
If you feel it is too far outside the scope of this thread, send me a PM or better start a new thread and point me, and others, to it.
Jonathan
Out of Spec?
Twister,
Jonathan
Out of spec means anything less than Bis80 or equivalent.
This was the spec they were all sold on up until CMP and Smith announce that the "new" lower spec of 620 is "fit for purpose".
Not 1 single rocna ever left the factory as anywhere near the spec that Smith demanded and that Holdfast and the Bambury's were contracted to make.
The introduction of a 620 spec metal by myself , against the wishes of Bambury, did not hit the market until 2010 in the main, and was still knowingly below what was being advertised and promoted by Bambury and Smith.
CMP entered this knowing that 620 was being used and continue to manufacture using this metal.
That is the new spec benchmark for the Rocna.
If you own one of these new ones , or if you are content to use the current one you have then be happy.
If you own one made in China between 2008 and mid 2010 then you will have a 420 one.
The only recourse for you legally is a refund from the retailer you purchased it from.
CMP have my total sympathy in this fiasco as they were lied to by Bambury and Smith in order for the sale to them to go through. They made initial statements as to what they would do as far as below spec product goes based on what they had been told by Bambury and Smith.
I would not expect them to be held to those initial statements as far as any liability goes and in taking the stance of replacing any that bend I feel they are going further than many other companies would in the same position.
The one thing that does need to occur though is for there to be a worldwide notice regarding the substandard shanks advising the boating , and general public of the problem.
That would go some way to restoring confidence in the brand and in CMP.
I somehow neglected to post Big Kudos for Pipler's of Poole, for taking back my Rocna 55 with a smile and no questions asked. A class act, and not only in this -- this is a particularly nice chandlery with particularly knowledgeable and helpful staff.
I exchanged it for a 100 pound Spade which Pipler's ordered in for me, and I couldn't be more pleased. The Rocna performed satisfactorily and never dragged (and I used it in some very challenging conditions), but was surprisingly hard to set in some bottoms, not infrequently requiring multiple attempts. In softer bottoms, I found that I had to let the Rocna settle for a while before gently backing down on it; otherwise it would just plow through the mud without digging in.
The Spade, just like my previous one (a much smaller one used for 10 years on a much smaller boat), behaves very differently to the Rocna -- biting into the seabed with extreme aggressiveness, and seemingly without regard for the nature of the bottom. Even in the difficult bottom of Mupe Bay, which has a lot of light rock debris over a stony base, it just bit right in without the slightest fuss. And that on several different occasions. To be honest, I am a little afraid of the shock load it puts on the windlass when it bites. I guess the fluke is sharper, or angled better, or maybe it's the lead ballasting which makes the anchor altogether denser. I don't know what it is, but it is very different from other anchors, including the Rocna, in terms of its setting behaviour.
As a bonus, the Spade is much easier to handle, at least for me and my boat. Either because of the lead ballasting or because of the geometry of the anchor, it always comes up right side up and pops right into my bow roller with the windlass. My Rocna tended to come up upside down, and needed to be horsed around with a boathook before it could be heaved in. In rough conditions, on a pitching bow, it was quite frightening to be grappling with a 121 pound pendulum.
But I digress -- this was meant to be a plug for Pipler's -- very good people to deal with!
Strain on the windlass. Watching yachts in Greece last year laying their anchors out at 5 knots astern made me wonder what the strain was on the windlass. Fine I suppose with a CQR which probably bounces merrily along the seabed, but if I did that with a Manson - which seems to set as you describe for the spade, I doubt whether I would even have much foredeck left!
I have had a similar problem with the Rocna coming up the wrong way round.
We have found a simple solution. Once the anchor is free of the seabed and you can see it just below the surface just go astern a little. The water flow flips it the right was round.
