Chris_Robb
In the light of evidence that my anchor is not up to spec, I intend to approach the chandler and ask for a replacement anchor, but I have not yet decided which of three options to go for. (1) Throw more money at it, and get a 20kg Spade (probably a stronger anchor but with the same fluke surface area as the 15kg Rocna); (2) a 20kg Manson Supreme for about the same money (and a bit shorter than the equivalent Rocna, so will fit in my anchor locker and will probably give my everyday bower more holding power in difficult conditions); (3) a 15kg Rocna made in Q620 steel (for the considerations that made me choose the Rocna in the first place, rather too long-winded for this post).
For your last option, it appears that you still trust Rocna/CMP - you must be bonkers! They stuffed you and are clearly continuing the same process. Go with a manufacturer with a proven record.
I think both the Spade and Manson are the equal of any Rocna. Do consider that these advanced designs are absolutely critical in copying all the designed angles etc. Grant Kings email clearly show that Rocna not only had an issue with steel quality but they also had fabrication accuracy issues - which would have affected performance.
