Scotty_Tradewind
I'm curious. What are the correct steel specifications for an anchor? What spec is used in ( say) a Bruce, or a CQR? And whilst one or two of us on here would know what a steel spec says, and what is meant by yield point and UTS and quenching and tempering, I suspect the very large majority havent got a clue. Nor do many know what difference the steel spec change on a Rocna has made to the force necessary to bend the shank - is it down by 10% 20% or 30% or more? Any idea? And how does this compare with the bending resistance of the shank of a Manson?
What I'm getting at is that we have here a situation where a company has done something stupid and with the help of a lot of Yanks on another forum ( if there is one thing the Americans are really world class at, it's complaining) , a panic has been whipped up. An American style conspiracy theory. A bit of a feeding frenzy and not totally disinterested either since some of the posters are Rocna's competitors and one is an ex employee.
But leaving aside the legalities ( you are undoubtedly entitled to send the anchor back) does the change in steel spec really matter? And lets not have MaineSails nonsense about a few bent shanks - I 've seen loads of bent CQRs and more than one Fortress. Anchors, like anything else in this world, will bend if enough force is applied.
So is a panic being whipped up here? Sure you can insist on your legal rights and send the anchor back but do you know that what you buy will be any better in real life use?
I suspect from what you say we're thinking along the same lines. After talking to Piplars and having now had 3PM's from R1, I am less concerned about my own anchor, it being one of the later 620 ones. I have been reassured that there is no weld problem and i will wait to find out more as to the qualities of the 620 steel when designer and 'Canada' release a statement.
I'm likely to be wanting to sleep on the anchor when cruising in the near future so I do need to be reassured
