petem
Just buy them for Axon. They cost peanuts and Axon will make whatever you want. Eg the ones below are all custom etched per my request - ok these are the more modern Contura5 actuators but you can order contura 3 if you want to keep the retro /original look. The ones below are red LED backlit so the letters glow - I would upgrade to that because it is so easy to do - but obviously not if you want to keep the original look
Axon was where I started and they no longer supply Contura 3's.
Probably teaching you how to suck eggs but Contura 5's are lasered / etched / engraved (I can't remember which) and loads of companies are happy to do these as one off's. I dare say you could but a $100 laser from Alibaba and make your own.
However, Contura 3's are pad printed which requires time consuming creation of the clichés and specialist equipment.
Looking at my switches, I have 8 which are landscape and Brian Wards should have stock. I have one fan blower / switch which should work in portrait and landscape and therefore Brian Wards should have stock.
That leaves...
1) Two bilge pump switches (if I omit the '1' and '2' it will be a common icon)
2) One Nav / Anchor light switch
3) One Cockpit light switch
4) Two wiper switches (if I omit the '1' and '2' it will be a common icon)
5) One windscreen washer switch
So out of 16 switches, I only need to commission 5 new ones.
