Highndry
What precautions do I need to take regarding the Oxalic/wallpaper paste mix as I rinse it off my topsides? Is it a case of as long as it's diluted enough, it's safe?
Oxalic acid is present naturally in some plants (Rhubarb leaves are full of it - that's why they are poisonous). So I don't think the Oxalic acid presents any environmental problems. The mould killer in the wallpaper paste might be a different matter, though.
I used Oxalic acid solution (no wallpaper paste) on woodwork from my boat, and just rinsed it off in the garden. The lawn where I did it hasn't taken any harm!
Of course, you need to keep it off yourself.
I'll maybe do it without the paste then.
Thanks for the help.
the paste is to stop it from running off vertical surfaces before it has had any effect.
presumably AntartcticPilot could apply it flat to his woodwork if he was at liberty to rinse it in the garden, so he wouldn't have needed it.
Be Very Wary !
SNIP
Be very careful with Oxalic Acid.
Andy
Yes. Although I think it is environmentally OK, it is nasty stuff. You can get severe skin irritation and/or burns and it is pretty toxic stuff, with about half a gram being the lowest recorded lethal dose. It can be absorbed through the skin, so skin contact is not just painful, but also can poison you. Death is from kidney failure, which probably isn't a good way to go either.
600mg /kg ! That is equivalent to 50 g for a typical 13 stone yachtie
That's good to know, I was under the impression it was about a teaspoon. Now I can eat 65g and still be OK600mg /kg ! That is equivalent to 50 g for a typical 13 stone yachtie
I've never used rubber gloves for oxalic acid and have never had any adverse effects. I think really, unless you are a right mucky bugger you are unlikely to get enough on you, of sufficient concentration to do yourself any harm. I usually use it by mixing it into hot water until it stops dissolving and then slap it on with a paint brush. I only use it for getting the stains out of wood though. I've no experience with trying to clean gelcoat with it.
+1It must obviously be that some peoples skin reacts differently to different acids,etc. I have used strongest oxalic solutions for years, always wear vinyl gloves, seriously avoid getting it near mouth. But have had this stuff on my arms and hands a few times with no affect. I use it carefully and wash off hands at end of job. I treat it with respect but never had a reaction.
