cliffordpope
The long rebuild and restoration of my 21' gaff cutter is nearing the end, and I am beginning to think about the business of moving it from my barn to the nearest water.
It is sitting on a 4-wheel trailer, whose axles are quite close together.
The boat has a long straight keel with a heavy lump of cast iron running practically its whole length. At present the trailer is supported on blocks, and the boat is securely chocked along its length. When I move the trailer, it inevitably flexes a few inches. As the boat stays rigid, this means that the keel sometimes lifts clear of its rollers at front or back, and also from the foremost or rearmost of the metal uprights.
My question is, should I strap the boat down so hard that the trailer is forced to conform to the boat, or should I remove all but the central cradle and accept that the other trailer supports will flex and not always be in contact?
Which puts least stress on the boat as the trailer goes over humps and potholes?
