Rib Transom Specs
Bigplumbs
7 Nov 2015
UK
If a new rib transom is rated to 75 hp which would be a 4 stroke probably weighing 150 kg.
If you wanted to go 2 stroke would you be happy to install say a 90 hp which weighs less than 150 kg.
I know a transom spec is about power and weight but would you think 15 hp over would be an issue.
I know it might have an issue with insurance
[165042]
25 Nov 2016
It's always a HP rating regardless of weight (there's probably a max weight too). The simplest thing is to speak to the manufacturer but I suspect you'll struggle to get insured if you overate the CE plate it's certified for.
[165042]
25 Nov 2016
Sorry but what relevance does that have? Like I said you have a max weight and a max HP rating. You can't fit an engine that exceeds either one and still maintain CE rating.
Boathook
5 Oct 2001
Surrey & boat in Dorset.
I suspect that the transom will take the power but how will the rib behave when you give it full throttle and as you mention the insurance.
Years ago I was chatting to a person on the Avon stand at a boatshow about an Avon rib that I had. It was rated at 15hp but the guy said they tested it with a 30hp. The boat took the power but they had to be careful not to tip it !
Bigplumbs
7 Nov 2015
UK
I think you are missing the point. If you read my original post. I am aware of the possible insurance situation. This is not what this thread is about or indeed CE rating
Momac
7 Feb 2008
UK
The power of the engine causes a bending moment on the transom due to the power at the prop x the lever arm to the fixing to the transom.
Too much power could cause instability or structural failure,
So it would be wise not to exceed the 75hp.
But why not try the 90hp as is only 20% over the recommended maximum. What could possibly go wrong?
SC35
13 Jul 2021
The manufacturer will have tested the boat with engines at the rated hp in the conditions it's expected to be used in.
Like a car, you can exceed those limits by tuning / increasing engine power, and you are "on your own".
Many people have done this, especially with tenders on this forum, and very few people have died doing it.
But ... if your transom is a fibreglass thing that is part of the hull and cracks appear ... you are on your own.
If the transom starts to un-glue itself from the tubes ... you are on your own.
Insurance claims could well be an issue if you have exceeded the plated HP ... you could be on your own.
On the other hand, if you only use the extra power fed in smoothly in flat conditions and you don't crash and the engine weight is about the same, you will be motoring past the slower boats .. in a category of your own 😈
Personally, I would go for max plated HP and no more.
[165042]
25 Nov 2016
Then what is it about? A CE rating is granted based on the design specification by the builder but obviously you know best so carry on.
Boathook
5 Oct 2001
Likely problems to the transom (and dinghy handling) caused by putting a bigger than recommended engine on the transom.
My boat and one of the dinghies pre-dates CE so it is common sense for me.
Looking at some of the warnings written in the manuals nowadays, common sense seems to be in short supply !
ylop
10 Oct 2016
Depends what your questions is…
Would I go out of my way to put a 90 on 75 transom- no that would be stupid.
If I had a spare 90 kicking around would I put it on the 75 transom - maybe but with some a big caveat that limiting the throttle (either mechanically or with operator intelligence) and fully knowing that if I had an accident that was not my fault and possibly had nothing to do with engine power that everyone (not just insurers), but MAIB, MCA maybe police would be saying I was wrong. And knowing that I’d struggle to sell it like that.
The reason for the 75Hp limit may be nothing to do with the mechanical strength of the transom, but the handling of the boat in its intended use setting. I’d look to other people with the same boat running 75Hp and see how close to the limit it seems. If it’s some novel or obscure boat either you are close enough to the builder to have the discussion direct or they have no idea and even 75Hp/150kg may be dodgy!
SC35
13 Jul 2021
It's also worth pointing out that most standard RIB and engine packages have an engine that is one step down from the plated maximum.
e.g. plate says 150hp, standard package might be a 130hp or 140hp.
Bigplumbs
7 Nov 2015
UK
A CE rating is a certificate of compliance to assist buyers with a Purchase. Once you purchase such a vesel you can do as you wish. Also it might prove to be news to you but Insurance is also not a legal requirement for a boat in the UK. Now I know you and others will interpret that statement as me saying you don't need Insurance. Well that is not what I said but you will of course decide otherwise
Bigplumbs
7 Nov 2015
UK
I was talking about a Rib. Where did dinghies get mentioned
Bigplumbs
7 Nov 2015
UK
Have you got a Rib
dunedin
3 Feb 2004
Third Party Insurance is often a requirement for many of the places where a RIB can be launched.
And anybody who uses a RIB with 70+ hp drive without at least third party insurance is taking a huge risk at best, probably antisocial and certainly unwise.
Momac
7 Feb 2008
UK
This depends where you want the boat to be in the water .
eg. On rivers and canals under Canal and River Trust or Environment Agency control a license is required and to obtain the license you need insurance.
SC35
13 Jul 2021
Have you got a Rib
I have access to several - sailing club rescue RIBS that I helm a few times each year.
I don’t own a RIB … yet, but that could change.
Am I allowed to own more than one boat?
stelican
25 Nov 2004
fareham hampshire
Do you mean a Helmsman's license or vessel license ?
It may be difficult to obtain insurance without a recognised Helmsman's qualification.
