Restoring my 1983 wood sportfishing boat in Costa Rica!
GringoJohn
19 Nov 2010
Quepos Costa Rica
www.QueposFishAdventure.com
We spent 7 days a week, 14 hours a day, getting her back to new. Had to bring it all the way down to the hull and do a couple of patches, put in new hull and motor supports (the wood beams the motor sits on) and then built a small cabin up front with the bathroom and a ton of rod holders! It was a blast, except for being so tired, it was definitely worth it, I wish I had taken more pictures, here are some before and after and a couple of during pictures.
Here's what we started out with, classic "Palm Beach" Costa Rica Gamefisherman with a but ugly cabin:
Then this is what we did with the cabin and floor and pretty much everything except the hull. We were going to burn it, but I think there was soo much oil and diesel in the wood, it might have exploded and taken out the ship yard here... so we took it to the dump :)
Here is what the front part of the boat looked like when we took out the floor and the hull. We left a little part of the cabin up front as you can see in the picture that became the visor. In the picture it shows pine boards going across, but before we put those in, we coated them with West Epoxy and surf board cloth so they are waterproof and we don't have to redo any of that. Here is the empty hull:
We then had to patch the hull. There was a rotten spot under where the motor support beam was. The rotten spot was only about 6 inches across, but since the boat has three layers of wood, we opened the first layer up really big, then made like a pyramid, opening the second layer up only half the size and then the hole that went side to side was only about 9 inches big. I called West and they sent me a book on how to do it, this little patch took over a week to redo. We did it with the same weightless Laurel Wood the boat was made with, and each layer we lined up the grains with the existing grains of the surrounding wood layer. Here is the patch when we finish, before putting the board on the outside:
We then had some good rot on the transom and back rail so we rebuilt those as well:
Then I got too tired to take any more pictures, but here is the floor and cabin after we put it back together a bit!
Here is a picture of the visor we turned the front part of the cabin into. That was a lot of work as we built it a couple of times until I got it looking right. We also built those two fiberglass boxes you see on the tower that is next to the boat so I can put all the gauges in one side and the GPS / Sounder / Radio in the other. I hate those ugly black cummins things, so I made the gauge holder out of glass and hole sawed it. I replaced the original gauges with the sea cruz gauges that have built in alarms, but I had to buy two temp gauges because the first one they send me didn't work, so I don't know if I would recommend them.
The bottom we treated with the Interconnect sealing epoxy and Micron 66 from Interlux. I really like the look of the blue color, and hopefully after 3 coats of their best paint, I won't see any buildup for the next year or so.
2 and a half months later, we got her down in the water. This is from about 5 minutes after I got it in the water. The boat on the right is the panga we built a couple of months ago. We didn't get to start it until a couple days later because I was waiting on a new Racor.
Here's the first run last weeek:
First trip out was yesterday, she beat my other two boats releasing 6 nice sailfish and a couple of 30 pound Mahi. It was a fun build, I need to take some more pictures...
Here's a before and after just to see the difference, I really thought it came out better than I expected, what do you guys think?
Before:
After:
GringoJohn
19 Nov 2010
Quepos Costa Rica
Yeah, it's a day boat that we charter, we never go out at night or over night, and it's always 80 degrees here in Costa Rica so the cabin was just an oven. Opening that up, we put the shade where the cabin used to be, and just left a small cabin up front where there is a bathroom and where we can hang the poles. Much more functional. Here's a pictures of the bathroom, definitely "Keep it simple stupid" :
GringoJohn
19 Nov 2010
Quepos Costa Rica
It's got a cummins 5.9 liter 250hp JWC. Runs about 19 knots (before it went 15 but we took off alot of weight!).
More info...let's see...
It's cold molded which means it's got three layers of 1/4 inch wood as a hull and no ribs or supporting beams. It's like a really big piece of plywood. But instead of being "steam molded", it's cold molded, which means laid up by hand in small strips on a mold and then injected with epoxy. The wood the hull was made with is called Laurel, which is almost like a balsa wood when dry, so this boat is super light, maybe less than half of what a fiberglass boat it's size would weigh. That takes all the strain off the motor when you are fishing and you catch more fish. Before everybody cries BS, the other day this boat was trolling around a log right next to my fiberglass boat using the same teasers and setup and this boat raised 13 sailfish, 3 marlin and 10 dorado, and the fiberglass boat raised 1 marlin, 4 sailfish, and 6 dorado. And it'll do that everyday, it the last 15 trips, it raised more than my fiberglass boat on 13 of those trips and we alternate captains and all have the same gear. It also has much less prop wash because the propeller doesn't slip as much pushing less weight. Means the fish see the lures better. Also burns half the fuel of what my same sized fiberglass boat burns, and it's a little bit faster.
omega2
17 Oct 2002
Essex Bradwell UK
any more of them lying around over there?? LOL
vas
21 Jun 2011
Volos-Athens
nice project and well done!
for some reason this pic looks too familiar to me :D
BTW, is there a rudder control down at deck level, or have to climb up there to helm all the time?
And you helm standing? tiring job this fishing!
cheers
V.
MapisM
11 Mar 2002
Absolutely, +1!
I prefer the revised look to the original one, btw.
Not necessarily more elegant - and elegance is pretty much an each to their own matter, anyway.
But It gives to the boat an essential, fit for purpose design which I really like. :encouragement:
GringoJohn
19 Nov 2010
Quepos Costa Rica
cheers
V.
We let the customers have as much fun as they want downstairs, but we have all the controls upstairs. My first year out, I had a guy get really really drunk and he thought it was funny putting the boat in neutral while I was trying to dock upstairs. Almost wrecked the boat, so I decided it's all tower for me. You get used to the rocking, I've got an awesome six pack under all my insulation! :)
GringoJohn
19 Nov 2010
Quepos Costa Rica
Love it, prefer the new look...shows of the lines of the boat far better.
It seems to almost have a Carolina flare, have you got any head on shots? Oh god that sounds so sad and geeky :(
Thanks. It kind of has the carolina flare hull wise, but they didn't bring the bow up. The was one of their earlier boats, the next boat they built they gave the bow a nice flare but it's essentially the same hull with just a couple of inches added to the bow. I'll include a picture of the next boat they made, which I hope to buy at the end of this year, which shows the way they changed the bow after they did mine.
This is the one they built right after mine. The hull is exactly the same, but they gave it a bit more flare:
And since you asked for it, here's a head shot!
Greg2
24 Jun 2002
Wow...,good job and a great post. Fishers have never been my thing but she looks great. Must have been a very satisfying project
