Replacing paddlewheel
You need to lose your fear of taking out the impeller. A few pints, or even a few gallons, will not sink you. The paddles are however very vulnerable to heavy lifting strops sliding along the hull at launch/liftout time. You may get away with slings 5, 10 or 20 times, but sooner or later it will cost you a new log impeller. In Falmouth mine seems to need taking out at least weekly in the season.
In the past, I've had a paddlewheel ruined by lifting slings, so I now always remove it before having the boat lifted. As for having to take it out frequently, simply painting it with antifoul a couple of times a year should resolve that.
The worst that can happen
The transducer can be pushed up into the boat breaking the securing ring, have a softwood bung handy :encouragement:
Wow, wouldn't want that to happen! Food for thought. But I wouldn't want the forward sling loading up anywhere near my transducer position either - the sling ought to be positioned by the root of the keel, not a couple of metres further forward.
Can always rely on this forum for wise advice. I hadn't really thought about the lifting strops sliding up and taking out the paddlewheel. The idea of an errant strop pushing the whole thing up into the hull is a bit scary!
Checking, it's an Airmar ST800 transducer and the info sheet says the valve housing as a sort of flap valve to mitigate water incursion when the paddle wheel and blanking plate are swapped. Think I will practice while it's out of the water all the same as access strictly one handed.
i removed my ST60 transducer prior to hauling this Saturday, expect to replace it in the skin fitting when afloat Wednesday
