ritchyp
Hi Members,
My fairly recently purchased 1992 36' foot Feeling has four dataline instruments mounted side by side just above the hatch above the companion way.
I sailed her for the 2nd time last weekend (The first when we sailed her from Ipswich To Southampton at the beginning of February.)
I noticed the wind speed not working but the wind angle did. Looking up to the top of the mast, its was clear that the anemometer was seized but the wind vane was still working. Reading the manual, it says there is a lubrication nipple that needs oiling once a year. I suspect that hasn't been done for several years.
The log worked but the readings were clearly wrong and now it doesn't work at al because the paddle wheel is probably choked up with river weed.
The depth gauge has always worked intermittently, showing the depth below the keel and the clearance required in the bottom right hand corner. When it is working it is accurate but it is quite often flashing numbers which oddly enough equates to the depth in feet so I wasn't particularly worried about it until we clearly touched some soft mud with the keel, just as we were tacking. I had been watching the depth like a hawk and the instrument was flashing 14.07 so 14 feet, we should have been ok with a draught of 1.8m . So now the depth sounder is not No bueno to! The instrument on the far right of the row displays the GPS and you can put waypoints into it. I'm sure they are linked as to turn the backlights on it has to be done on this instrument. I don't use it but it does give out an annoying continuous tone if you dont press navigation and the GPS Coordinates appear. I read that they are linked to a control module which sends or receives Nmea 0183 data.
mounted at the chart table I have an old Garmin colour chart plotter and the blue chart card has 2005 on it. There is also a DSC VHF radio linked to a class B AIS transceiver.
Mounted above the Binnacle is a Raymarine E90W Chartplotter/MFD that has its own built in GPS but doesn't appear to be linked to anything, not even the the EV1, AC100 & P70S autopilot and head unit. Whilst repositioning the EV1 compass sensor which was out by 40 degrees because whoever installed it broke one of the 4 clips that holds it together and keeps the sensor unit with the arrow pointing towards the bow. there was a spare Seatalk-ng socket on the end of the 4 way Bus connector so I will connect that to the E90W so I at least have the two Raymarine instruments networked.
I also have wireless capabilities as there is a Digital Yacht Long range access point ad an iNavconect wireless router connected to it and the E90W has a Seatalk-hs socket on the back (Just a waterproof RJ45 cable really.....) So I have options! Go all wireless or be prepared to do a lot of wiring.
I have a little technical knowledge and I have a enough skills, if I had more knowledge on the subject, to sort it all out myself. There wasn't a lot of money left in the kitty to be spending thousands on this and I forgot to mention, I want to add a radar scanner. She has an active dual band radar transponder, which I managed to get working again due to neglect and corrosion.
It all boils down to funds essentially. The price people are asking for old dataline units is crazy and I suspect that the head units are ok anyway but it is the transponders and stuck paddle wheels and anemometers that are the culprits. I've been reading threads on this subject but then i saw that those threads were from years ago. I still think "Buy New" is the best solution because I'll spend hundreds on getting this old system working again but the technology is early 90s and Im sure for a few hundred more. I could have wind angle/speed, Log and depth & sea temp all up and running. It would be nice to have the 110mm square units working as repeaters but also have all that data on the MFD which is just young enough to have all that data and radar, AIS depth and tidal direction on the screen.
My main issue that I need to address is the depth sounder and a new wind speed and angle system (which i can send to the auto pilot as its in wind vane mode - Virtual) If I buy new transponders, will they work on existing wires? If not, I have to go wireless. Just those 3 instruments working wirellessly will be about 300 quid for each. Its such a minefield and there are so many products out there. I could remove the depth transponder and get very wet by giving it a clean in case it was painted over with antifoul paint or buy a cheap Nasa Clipper transponder and head unit which might fit if I have enough room in depth behind but its completely standalone (3 wires) no interconnectivity.
I have been typing for over an hour now and spent all day trawling through forums to get some inspiration but I've run out of ideas that are within my budget so I am asking for some pointers and advice and maybe something I hadn't considered.
Thank you if you are still reading this because I have gone on but I needed to explain what I have and what needs replacing to give you guys as much information as possible.
The best of regards
Ritchy
The best of regards
Ritchy
