Poey50
RISK is a function of PROBABILITY OF EVENT and SEVERITY OF OUTCOME.
SEVERITY OF OUTCOME is conditional on the SITUATION.
The failure modes of LFP all tend to binary. The failure modes of LA tend to incremental.
If the SITUATION is a long passage or presence in a remote location then the RISK associated with LFP only is very high compared to LA.
How do you configure a system that mitigates the risk?.... while maintaining the benefits for LFP and keep it simple. In particular, better harvesting of charging sources and more time-flexibility due to better partial discharge performance.
...and you don't need to be physics genius to install and maintain it.
I agree with all that. There are several good solutions involving separating charge and load circuits. Good DIY systems and expensive integrated systems like Victron's do that. There is one straightforward solution using the other kind of drop-in hybrid system - lead acid to run the safety-critical circuits, LFP for the luxuries. Each on a separate circuit so chemistries are not combined. Charging usually to the LFP with the lead acid maintained on a B2B from the LFP. If LFP fails then all charging can be switched to the lead acid. It makes use of the advantages of both - high energy density and ability to take current of the LFP; the ability of the lead acid to take some abuse and remain reliable.
