lustyd
Just quoting this part of the original post for those suggesting Andersen connectors, which also need a pretty hefty crimper and are not cheap themselves.but the installation video refers to £47 special crimpers!
If you wade through the link I offered in Post 16 you will find members who have used solder. One reason for solder is that you can deconstruct and use the terminal or socket again whilst crimping effectively makes the terminals one use only.Andersen Power Pole contacts can be soldered.
£47 is the cheap end of pro crimp tools.
If this question was aimed at my post.Do you need to move this often? If not why not use bog standard insulated spade connectors.
Always good to think back to basics.Do you need to move this often? If not why not use bog standard insulated spade connectors.
When it’s at its most efficient?tend to unplug our fridge at night.
It doesn't really need to be on at night, it only gains a few degrees.When it’s at its most efficient?
No, it was in response to the original post.If this question was aimed at my post.
If wired correctly you should never have reverse connections.Always good to think back to basics.
It's good to prevent reverse connections, but if it's really only moved once a year options like terminal posts or whatever would do. I tend to unplug our fridge at night.
If you use an Anderson plug and socket, and it was wired correctly initially, then it is impossible to connect incorrectly (similarly to a cigarette socket can only be connected the correct way)If wired correctly you should never have reverse connections.
I always have a female connector on the negative side and a male connector on the positive side of a device. The power wire cannot then be plugged in incorrectly. You can also stagger the connections so everything lies flatter if space is tight.
If there is an on off switch at the fridge, or switch panel why unplug?
That is one of many options.If you use an Anderson plug and socket, and it was wired correctly initially, then it is impossible to connect incorrectly (similarly to a cigarette socket can only be connected the correct way)
Jonathan
