dgadee
I will probably replace a Yanmar 3gm30F. Ideally keeping the same shaft and folding prop. Anyone done this and what did you replace with? Yanmar again or alternative?
There are few compelling reasons for not replacing like with like, unless you want to reduce weight or change the shaft horse power. Yanmar seem to have got the engine sorted, and spares are not horrendously expensive, as are green engines.
EDIT
Just realised it is not a 'current' engine, sorry.
The present range of comparable new ones is
3YM20 15kW
3YM30AE 21 kW
3JH5E 29kW
but there's almost certainly an engineering shop that does fully reconditioned ones..
I also took the opportunity to put in a flexible drive coupling which made alignment less critical and easier.
What type did you use? I was wondering about the Aquadrive but the price seems high just to reduce the time spent in alignment.
I replaced my 2GM20 with a 3YM20. Allegedly interchangeable in size, in fact rather larger.
An outstanding engine, after 3000 hrs, I've never regretted the change.
However the 3YM20 is considerably more powerful then the 2GM - 23 cf 18 bhp continuous rating but infinitely more economic - 1.5 litres/hr on average.
The 3YM30 is not quite as big an improvement over the 3GM30.
The Yanmars are designed as marine engines - all their direct competitors are marinised versions of industrial diesels - the base engines are all thoroughly sound but the marinisation can vary in effectiveness.
The only stricture I'd level at the Yanmars is that the Hitachi alternators are undercooled, underpowered and melt under boat power demands for Med liveaboards.
From my experience I'd definitely suggest re-engining with another Yanmar, though there are many other cheaper alternatives.
.. but if your current engine is still functioning (why do you think it needs replacing?) you would probably get a good part exchange deal from a Yanmar dealer.
