sailaboutvic
I have a Lewmar bow thruster with a props on each side , there a round zine held by a Allen bolt on each prop shaft at the end , once remove the Zinc comes away which leave a nut and wash that hold the prop on , the prop should then just slide off ,
The prop has a slot , it slide on the shaft then the slot is located in a pin that goes through the middle of the shaft .
last time I tried to get the prop off I manage to get one side off but what every I try the out side just wouldn't move .
I try hitting it with block of wood for the other side , wripping a rope round the prop and using that as a puller , tried a small amount of heat on the prop , also plenty of WD40 ,
there no way of getting a pulley in there .
Anyone with any ideas , I like to get it out this year to give the prop a good clean ant the tunnel a good. of of AF
Other then cutting it off which I rather not do I type of run out of ideas ,
I have a while to think about it as I won't be doing it will March .
Thanks in advance
Thanks in advance
