thinwater
In fact, anti-foul is commonly removed by dry vacuum sanding in the US. In fact, wet sanding and scraping are mostly forbidden unless you have a contained concrete pad.
If the vac (HEPA filter) is good there is very, very little dust. You wear and N95 mask. The dust is not as toxic as one might think (OSHA has studied this) because the anti-fouling agents are 75-85% gone and the resin is well cured.
The chemical strippers are more dangerous than contained sanding dust. If they can penetrate paint in minutes, they can sure penetrate gloves and skin in minutes. Methylene chloride is basically banned, and NMP is moving that way after studies revealed with the chemicals were doing to people.
Very coarse paper helps. 40 grit.
