panda9958
Anyone have any experience of these? I've seen a few for sale with Volvo KAD32 170hp diesel at very attractive prices. Are they any good? They appear to offer plenty of space for the money.
I found a Regal with a KAD31 diesel. Are these engines essentially the same apart from the supercharger? I think they have a 6' headroom in the cabin which would suit me well. Looked at a few Sealine S24's and the headroom was not high enough. Would this get under Oxford bridge, the low one with canopy down?
K means Kompresser (Supercharger) so should be AD31 or KAD32 no such thing as KAD31, so you need to check for a typo.
Doubt the Regal will fit under Osney, does it have a Radar arch? even without one it will be very tight, used to have an older similar Sportscrusier and it only just sneaked under with about an inch to spare, think the Regal with its higher superstructure would be too high.
I would also check if its been re-engined, I dont remember seeing any small Regal's factory fitted with diesels in the early 90's (When the AD31 would have been around).
If no radar arch and all the covers down it may fit under (I've been through in similar size Four Winns and Maxum sportscruisers), but you will only have inches to spare, and if the level rises while you are up there you are stuffed
Hi Mark
Thanks for the info. The Regal 242 has a diesel and duo prop. It's looks clean, but has been around a long time. Maybe it has been re engined, but I suppose that's not a bad thing. It's a 97 model.
