stillwaters
Of course I will, what else could I do?
Otoh, when I tell her that something was suggested here in the asylum, she tends to care more than if it's just my view...
Who else is for bright pink then?
Positively +1, I was completely unaware of this type of "gelcoat-only" alternative.v interesting Bouba - thanks
I would just love to know what sort of material is used as OEM stuff by these yards!![]()
regarding the teak, (and the 10mm borders hidden behind)
have you considered leaving the teak in place and have it dried thoroughly,
and than cast it in a resin / epoxy ?
I mean, put so much epoxy over it that you don't see the teak anymore,odd idea Bart,
how would P solve the two problems that spring to mind:
UV protection
Antislip properties (whilst keeping the teak visible somehow...)
out of the box thinking, not sure it's viable though
cheers
V.
(like epoxy floors for domestic, most of my office space are done with this stuff)
and than finsih with a extra layer gelcoat or , antslip or .... (as mentioned above)
That is actually quite clever, if the epoxy can be tinted. The wood should dry in the Italian summer and the weigh wouldn't matter as MapisM is a displacement boater so it would make him go faster. The only problem I see is that it is a one way street, you could never undo the job if you changed your mind.I mean, put so much epoxy over it that you don't see the teak anymore,
Actually nope, I didn't, B.regarding the teak, (and the 10mm borders hidden behind)
have you considered leaving the teak in place and have it dried thorrowly,
Oi, that was the past.weigh wouldn't matter as MapisM is a displacement boater
Be careful, I heard he has a really good hullOi, that was the past.
For the future, after stripping the teak and tuning the props, I might consider challenging Portofino and his Itama in a rough sea race, as next step...!![]()
The fuel consumption figures sound about right because they are roughly midway between the figures I get with my current F630 and those that I got with my previous F53, both of course similar kinds of boats. I'm guessing that the main reason for other manufacturers not openly publishing speed/consumption figures in their literature is that they are leaving themselves open to legal action in trigger happy markets like the USA. You can imagine some redneck American loading his boat up with fuel, beer, bbq food and several of his fat friends, not achieving the stated speed and consumption figures and taking the dealer that sold him the boat to court for millions of USD in damages. In any case there is enough info out there in boat tests and engine manufacturers' literature to make an educated guess about the fuel consumption of most boats. All the same it is impressive that your boat as near as dammit still achieves the speeds that DP said it should and on that basis you'd expect the fuel consumption figures to be pretty accurate as wellPS: Apropos, is anyone aware of builders who published tables like this in their official brochures?
Fuel consumption looks a bit optimistic .-see the pic
Surprisingly it is beamy too 4.9 M rest of the field lower.
