Graham_Wright
Cheapest safe way. CO2.
Can't afford water mist and can't afford the mess and engine destruction of powder.If this is for a boat there should be no reason to use CO2 onboard unless you want to commit suicide.
Water Mist or powder if you like fighting fires unable to see or breath easily.
I extinguished my engine fire with CO2 and survived. What did I do wrong?
Well, CO₂ kills a fire by removing O₂ from the fire triangle, Oxygen, heat and fuel, but in a confined space like a boat it can also remove the O₂ that you need to live. Sounds like you were lucky this time.Can't afford water mist and can't afford the mess and engine destruction of powder.
To me to put oit an engine fire in an enclosed engine room is to have a fire sensor (smoke of flame) with a remote operated CO2 extinguisher so that the fire can be comptroller without opening the engine room hatch.
Once the fire is out access should be a lot safer.
That is not helpful!Your mistake was having an engine fire because you neglected some basic checks. Details are in your other thread, yes?
Hi DB ... just a little confused ...Back in the 70s I had a petrol fire on board my Stella, out in the N sea. Flames ran all along the bilges & up around the engine (Stuart Turner). I had recently been given 2 free foam extinguishers by Chubb as part of the deal to fit them to my factories & take on a service contract.
It took both of them to put the flames out as the petrol ( about 1+ pints, started off with a spark from the ignition) was running along the top of a flooded bilge (we had a serious leak & were pumping every 30 mins) & as I put one section out it ran back from another. I had to lift all the floor boards & engine cover to get at it.
It was extinguished on the last squirt of the last bottle. I did not have a problem with being able to see as described in #10 inspite of using in confined spaces. In fact I was hugely impressed with them. It did make a mess but apart from my crew's open clothes bag getting an accidental "squirt", we were able to wash the powder into the bilges with some buckets of water & a soft broom. The engine got a similar treatment & did not suffer much from the ordeal either. We then pumped it out via the bilge pump.
So I dispute the doom mongers, from my own experience of actual use. My current boat is fitted with powder ones.
On a more amusing note.
We were racing in the Crouch & short tacking along the shore. My crew slipped & kicked the extinguisher off its bracket; whereupon it immediately started to discharge. It spun round on the cockpit floor & under/over the seating, like a giant catherine wheel spraying everything, including him, in white powder. Not realising what had happened it momentarily scared the c..p out of us both.
Neither of us could move as it turned the varnished wood floor & seats into a skating rink. We had to flush it into the bilges with buckets of water & wash the area with a soft brush.
The boat near us thought that we had blown up, as a cloud of powder shot into the air
I do have an external CO2 extinguisher in the cockpit deep locker. It can be activated from the locker and discharges through the bulkhead. One day I’ll connect it upTo me to put oit an engine fire in an enclosed engine room is to have a fire sensor (smoke of flame) with a remote operated CO2 extinguisher so that the fire can be comptroller without opening the engine room hatch.
Some time ago I had an automatic fire extinguisher that went off due to heat from a running engine in an enclosed engine box.That’s overkill for most of the boats that folks sail. There are lots of low cost, safe to use, automatic engine room extinguishers available, Attach to bulkhead and forget.
