MapisM
Ref. possible improvements, TBH I'm not sure I'd bother recrimping everything in absence of any problems.P, how were the connections made on your boat?
How would you improve the ones in my pic?
Though the size of your wires makes me think that they are meant to carry some decent current (albeit DC, surely), which makes hard to understand the choice of not fully insulating the connectors.
There are fully enclosed cases designed for that type of connectors, which can be fitted also if they are already crimped (like this, just as the first example I googled for), but I think you should remove those small blue plastic insulations around the crimped part of the spade connectors first, and it might be tricky to do that without damaging also the metal.
Back to your first question, below is how buttons and switches look like, behind my dashboard.
'Scuse the loose cabling, the pic was taken before they were reordered a bit.
What is relevant is that all of them, bar none, are just contacts controlling a set of remote relais, hidden inside the electrical panel (the second pic shows some of them). So, the current they handle is close to none - milliamps, I would guess. Probably, the led inside them is what demand more current...
