Danny Jo
Freestyle is approaching the end of her nineteenth year with her original Perkins M30 (29 HP 3 cylinder diesel, believed to have been manufactured by Kubota) having done something in excess of 6000 hours. I say "in excess of" because when I acquired her 12 months ago she had 6300 hours on a meter (one that is driven by engine vibrations) that had ceased to work. In other respects, the two previous owners have evidently not neglected the engine, it was recently fitted with a new gear box and it starts like a dream. I may be a little underpowered for the Menai Strait, getting 5 knots at around 2100 revs and, flat out, just over 6 knots flat plus a lot of black smoke. Fuel consumption is a modest 2.3 l per hour at 5 knots. After 150 hours use last summer the engine has started losing fresh water coolant, probably but not definitely from the fresh water pump. The engine has two fairly substantial design glitches: (1) It is all but impossible to tighten the alternator bolts after fitting a new alternator/impellor belt, because you cannot get a socket onto the nut and there isn't enough room to swing a spanner more than about 5 degrees; (2) The manual fuel lift pump works only with the engine at top dead centre (according to the blurb), and I've yet to find top dead centre.
OK, the engine is good for a few hundred hours more, but I reckon I am going to have to do something fairly major at some stage, and if I am going to fit a new engine, shouldn't I do it sooner rather than later so that I, rather than any future owner, get most of the benefit of the investment?
I've tried googling the question, with little success bar a reference to a previous thread on the PBO forum last year. Can anyone point me to a website which does engine and prop size calculations? Or two possible sources of expert advice in the North Wales/North West England areas?
Finally, some questions:
