Recommend me some adhesives
wonkywinch
30 Jul 2018
Hamble, UK
I know you're a sticky lot so looking for ideal adhesives for two jobs that need doing.
1. Rubber seal to lazarette door.
2. Electronics plastic box to solar panel case. This pulled off but not a way to screw back in as reverse of solar panel is behind the cloth. Presently a bit fragile as you can see the panel connecting leads potentially under strain bottom left.
You could use superglue on the rubber seal.
That's a good call. Spray activator on hatch and a tiny amount of superglue on rubber. Less is more with superglue.
Contact adhesive seemed a once popular choice but ive seen many a rubber seal hanging off thats already had the contact adhesive treatment.
…, also some 3M VHB 4932 sticky pads…
I’m a big fan of 3M VHB tape. Someone on here was saying recently that some boat manufacturers are using it to stick windows on boats.
Re CT1, I’m convinced that the clear stuff is not as strong/sticky as the coloured stuff.
