Recommend me a rev counter
Graham_Wright
30 Dec 2002
Gloucestershire
www.mastaclimba.com
I would like an analogue rev counter that takes its information from a crankshaft sensor as opposed to sensing alternator output.
Does such a thing exist?
Ebay searches have not revealed one.
Digital display ones exist (I have one somewhere if only I could find it!).
Ebay searches have not reveled one.
Why ?
Are you reinventing the wheel?
Why ?
Because it is a better engineering solution.
The one I have currently reads correctly at 400 rpm but progressively under reads at higher revs. Why? Belts slippage maybe or a defective gauge which can only be adjusted for one speed.
Sensing from an inductive or optical mark on the rankshaft seems much more elegant.
I have not seen an analogue one that uses a crank sensor. I fitted a Durite one 13 years ago and is still perfect. https://www.durite.co.uk/durite-sho...-dial-12-2/052530-led-illuminated-marine.html. (latest model, looks identical). Which uses the alternator connection. It has a calibration adjuster which I set at cruising revs using a RPM app on my phone which gave me accuracy over the rev range within the resolution of the dial so, for me, no benefit of a crank sensor.
Several analogue sensor types available (crank or any other spinning part), -even wireless!
One on Amz
But there is no reference to a sensor. The output from an alternator er alternsates - probably a sine wave.
Outputs from pulse sensors are square wave (or sawtooth). With an engineering background, I would hope the interface would be defined.
The Amazon entries are typically Chinese with adulation and repetition.
VDO make analogue tachos that work from a sensor. I have 4 here, 2 at each helm, the sensors aren't cheap though.
I have just replaced the 2 at the lower helm with KUS tachos, these work with the engine sensors or tachos. I have spare VDO gauges, but they are 24v.
See KUS Tachometer Gauge 3000 RPM with Hourmeter (Black) But i bought mine on Ali Express.
In many cases sensors are referenced in detail. The one I randomly linked to has a description:
Tachometer Sensor Model: M18 x 1.5 / M16 x 1.5
Operating Current: ≤60MA
Operating Voltage: 12V / 24
Range: 0-3KRPM
Input Signal: Additional signal from tachometer sensor, engine, alternator, ignition coil, crankshaft sensor, etc.
If you order a kit with (e.g. NPN-) sensor etc. there should be no compatibility issues. Autometer offers a pickup to fit on the alternator outside, which works with many brands if you don't want their gauge.
In cases where the original signal source can not be found/fixed easily, a replacement seems tempting. Especially if at a fraction of the cost.
When KUS state "engine signal" do they mean alternator W-terminal to send the Wave frequency?
