ganter
Hi,
I've removed various stainless-steel fittings; tangs, plates, shroud caps, etc, from the aluminium mast for inspection - all were riveted from new.
For the re-attachment of them I intend to use Duralac to create the seal between the two metals (of course) but what spec is required for the rivets to attach them to the mast?
They must obviously be of the utmost high-performance in terms of Load and Anti-corrosion.
Please only post if you have direct knowledge of this topic.
If you find yourself starting your reply with; "I haven't done this personally but..." then don't bother posting.
Thank you in advance.
ganter.
ganter.
