Re-rivetting SS fixtures to aluminium mast
ganter
9 Dec 2013
Hi,
I've removed various stainless-steel fittings; tangs, plates, shroud caps, etc, from the aluminium mast for inspection - all were riveted from new.
For the re-attachment of them I intend to use Duralac to create the seal between the two metals (of course) but what spec is required for the rivets to attach them to the mast?
They must obviously be of the utmost high-performance in terms of Load and Anti-corrosion.
Please only post if you have direct knowledge of this topic.
If you find yourself starting your reply with; "I haven't done this personally but..." then don't bother posting.
Thank you in advance.
ganter.
vyv_cox
16 May 2001
France, sailing Aegean Sea.
coxeng.co.uk
You will find two grades of aluminium pop rivets on the market. They are either described as 'aluminium', 99.9% pure, 1xxx grade, or 'alloy', an aluminium/magnesium alloy of 5xxx grade. There is a world of difference in the strength and corrosion resistance of the two. RS components do both and no doubt plenty of other quality suppliers do also.
Champagne Murphy
5 Jun 2011
Suffolk
So where do ‘monel’ rivets come in that classification?
PetiteFleur
29 Feb 2008
Suffolk
I always thought you always used Monel pop rivets for this application - this is what I've used in the past, much stronger than Aluminium and no corrosion as long as you use Duralac or similar. They are MUCH harder to fit and you may need to use a Lazy Tong or long handled riveter. You can buy them in small quantities and length.
ganter
9 Dec 2013
I was hoping for "Monel" to come up - I have an Air-Riveter - but what exactly are the properties of Monel Rivets - and why are they the choice?
What does "Monel" mean - in terms of metallurgy?
I apologise for my ignorance on the subject.
lw395
16 May 2007
Monel.
Expensive and you'll want a good tool.
I use these for anything high load.
For light load, ordinary ali is fine. You don't need monel for the courtesy flag halliard, but just about everything else?
NormanS
10 Nov 2008
I used monel rivets for the mast steps on both my masts. No way was I going to use any second choice material for such a safety critical installation.
ganter
9 Dec 2013
Here you go:
https://shop4fasteners.co.uk/monel-dome-head-rivets.html
Alloy rivets are pretty good but they tend to struggle in a salty environment. Good you have an air gun OP, although the newer lazy tong riveters will react a 1/4 in monel rivet, you do tend to suck your shirt lap up your backside as you do it.
Could you expand on what you mean by that please re; Lazy Tong riveters and shirts getting sucked up, etc...
Thanks in advance.
NormanS
10 Nov 2008
I used a "Faithful Long Handled" riveting tool, which at £20 from Amazon, seems like a much better buy, and is much more controllable than the lazy tongs type. My mast step rivets were 6.4mm (1/4").
john_morris_uk
3 Jul 2002
At sea somewhere.
I fitted all my mast steps with the mast up and working from a bosuns chair. Monel rivers fitted with a Lazy tongs riveter but at each station I had a length of line round my torso and round the mast to brace myself against.
I marked the height and then put the step up against the position and marked and drilled the first hole (usually top right). I then riveted the step in place using the first single hole but didn’t cinch the river up completely. I then used the stainless step as a guide/template to drill the remaining holes. I used a Makita cordless drill and a Cobalt drill bit. My steps were supplied with four polythene washers to fit between the step and the mast and the reason I didn’t cinch the first rivet up tight and to breaking off the mandrel was to allow enough slack to slide the nylon/polythene washers in place. I was always worried that I was going to drop one of these polythene washers but in the end only dropped one which I replaced by cutting one (rather crudely) out of a polythene bag.
Monel rivets all the way up the twenty or so steps I fitted. (Obviously you fit two steps either side at the top to stand on when you’re working at the masthead.) I didn’t have any great difficulty popping the rivets with the Lazy Tongs riveter with a line round my shoulders/torso, but I’m a big guy (over 6’2” and used to work out a lot).
The steps have been up a few years now. They’re the fold in sort and one draw back is they’re a bit stiff to deploy or stow as you’re climbing up or down the mast. A squirt of PTFE spray lubricant helps. The very thin nylon/polythene washers isolating the stainless mast step from the aluminium mast have worked well with no signs of any corrosion at all so far.
vyv_cox
16 May 2001
coxeng.co.uk
Monel 400 used for pop rivets is a copper-nickel with about twice the tensile strength of aluminium alloys in the 5xxx series. It is expensive and for that reason is rarely used by professional spar makers. The vast majority of rivets used in mast construction are made from 5056 alloy. Very few applications on most masts require the additional strength of monel, and the corrosion resistance of 5056 is perfectly adequate, particularly when bedded in Duralac.
My Selden mast is well over 30 years old and riveted throughout with aluminium rivets that I assume are 5xxx types. I have never seen any rivet that might be monel or stainless steel. There is no corrosion and it has never been necessary to replace any rivets.
BabaYaga
19 Dec 2008
Sweden
Are you sure about this?
In their booklet 'Hints and advice', Seldén recommends monel rivets:
'Bearing in mind the risk of corrosion, monel pop rivets are the best choice for fastenings, particularly when attaching something to a thin-walled (< 3 mm) section.'
It would surprise me if they didn't follow their own advice.
I have a 40 years old Seldén mast and have always believed the rivets were monel.
vyv_cox
16 May 2001
coxeng.co.uk
How old is the booklet? 5056 rivets have excellent resistance to corrosion. In these over-cautious days they may have different views from those of years ago.
