Robert Wilson
Somehow my main halyard and topping-lift have become entwined within the mast. Also the main enters the mast on port and exits on starboard (topping-lift vice versa)
Apart from increased friction it appears that there is a structural cross-member near the top (10 cm below the top sheeves which is causing damage to the rope).
Any bright sparks know how I can re-reeve the two bits of string? I can climb the mast and remove the top sheeves but how do I get a messenger line down to the entry sheeves (which have restricted access to inside the mast)?
I tried dropping down a fishing weight on a thin feeder line but I couldn't see/ capture the weight at the entry point. I know it reached somewhere near because when I re-threaded the halyard the weight became jammed in the entry sheeve. Much cursing (and tremendous good luck) managed to extricate it.Phew!
I have a long length of "electricians wire threading flexible rod" which I'll try with today, but after that I'm stumped.
As usual, thanks in anticipation.
RW
RW
