Neeves
Most chain is mild steel and thus soft and prone to abrasion. Galvanising it harder than the underlying steel. If you are going to regalvanise realise that ungalvnaised chain that you have been using has been corroding and abrading. Really you want to regal as soon as you detect serious corrosion. If you anchor a lot, live aboard, you will not see the corrosions as every time you anchor the rust will be abraded off.
If you are unsure - measure a good few links, of clean polished chain. The usual rule of thumb is discard if you have lost 10% or more of diameter.
But if the financial equation looks suspect - buy new chain.
If you are regalvanising - Geoff is a sailor and will have more sympathy for what you need.
Jonathan
Jonathan
