prv
New boat has a Raymarine RD218 radar scanner, the kind that connects to a C70 display, so before it all went digital / ethernet but not absolutely ancient.
The cable was split and joined with a choc block to allow the mast to come down. The end at the bottom of the mast does not look good - almost too short, corroded, raggedy, and bound with PVC tape slightly further up, as if it's been pinched/crushed at some point.
This is obviously specialist cable - it has thick power cores, thin control cores, and a couple that look as if they might be coax that presumably carry the signal. It also looks like it might be difficult to disconnect at the scanner end, disappearing into a sealed metal box inside the radome.
Because of the second paragraph, I'd quite like to replace it with new. Because of the third paragraph, this is not as simple as replacing a lighting or VHF cable.
How necessary is replacement? By which I mean, will the raggediness of the cable be affecting the quality of the picture? Or is it actually a digital connection and if the two units can talk at all, they'll work fine?
How easy is replacement? In particular, can replacement cable be obtained, and what sort of connections are inside that metal box in the radome? While we're at it, presumably there's a better way of connecting the cables than choc-block?
Thanks for any insight from anyone who knows these radars!
