Raymarine Chart Plotter & External GPS
Travelmate
17 Sep 2007
Borneo
The Raymarine GPS antenna on the chart plotter has become unserviceable. Can I use the NMEA feed from an active GPS antenna or another GPS to feed the position data and other info into the chartplotter.
Tony
Re: Raymarine Chart Plotter & External GPS
Tony, it depends on the model of plotter...
Is your antenna a simple coax connector or a compound plug (black plug with usually seven pins..)? If it is a coax connector then no, if compond then possibly yes.
It also depends on what NMEA sentences the plotter can receive - this will be listed in the back of your owners manual.
As usual, answer a question with two more questions! Good luck,
Ross
My raytheon rl70 radar happily accepts nmea from my lowrance plotter without any fiddling, if i wanted to i could feed it raw stuff from the external gps which feeds the lowrance
Stu
The plotter will accept NMEA information from a GPS.
Found the original spec sheet for the antenna. It is model 125 with 5 wires. Yellow is NMEA out from the active antenna. Will simply connect NMEA out from another GPS (Garmin) into the display.
Should work.
Thanks for the input
Tony
Tony, have you tried replacing the watch battery inside the 125?
Connected external GPS to unit with no luck. Display head would not show position. The 125 GPS antenna flashes red, then orange a few times and now and again gives a green flash indicating a position fix. Fix will last a few seconds before it drops out. Hand held GPS will generate and maintain a fix from inside the boat. Display head and 125 is on its way back to Supplier for second time in the last few months.
Interesting photo on battery inside 125!!!
Thanks to all who replied.
Tony
