Raw Water Cooling Corrosion
tinkicker0
6 Mar 2008
Under a cloud - its just started raining
Recent thread had me wondering. How long does a saltwater cooled engine block generally last before corrosion eats through the cylinders?
Reason I ask is that my motor is raw water cooled and has generally been used in freshwater as it is now, so not too concerned, but it has had about 5 years use in the sea at some time in its past. Of course I replaced the manifold and also had to replace the circulation pump but if I were ever to return her to the sea, how long could I expect.
Mercruiser 3.0l
[2068]
19 Sep 2002
It's not normally the block that dies, but the manifolds and risers.
If the manifolds and risers are changed every 5 years, there is no reason why the block shouldn't continue. There are plenty of 15 yr old plus petrol engines out there still running.
Poignard
23 Jul 2005
South London
My directly cooled engine is 30 years old and has always been used in sea water.
I replace the anode every year because the existing one is decayed, which shows it's doing it's job.
prv
29 Nov 2009
Southampton
There are prehistoric lumps in old sailing boats still going after many many decades.
I keep an eye on the anodes in my 2GM20; they're wearing away at a moderate pace and as long as I change them when required I expect the block to last indefinitely.
scottie
14 Nov 2001
scotland
It ironic that with a engine designed for a pickup truck that the first part part to suffer from corrosion is the marinised exhaust system.
GrahamHR
12 Nov 2009
Cheshire
The American 3.0 / 4.3 V6/ 5.0, 5.7 V8 engines etc don't have an anode except if there's a heat exchanger fitted like mine ( why not, who knows !)
GrahamHR
12 Nov 2009
Cheshire
Versions of those engines fitted to pick up trucks were cooled by an antifreeze/ water mix that contained corrosion inhibitors; a bit different to salt water !
Why do VP fit anodes to some of their raw water cooled engines and not to others? Cost I suppose, coupled with their biggest market for such petrol engines being.for boats used in fresh water; those same engines better suited to salt water use with "closed" cooling do contain anodes.
