boatmike
Sweeping the shrouds back acts as a backstay, and stops the boom going out.
That's much the same regardless of rake.
Plenty of British fore and aft rigs had upright masts and booms extending over the stern.
I suspect the schooners evolved through a development process, what was fast locally got copied and taken further.
There may have been other influences such as availability of the right timber and a history of smaller boats with rake, such as 'cat' rigs.
Also perhaps fashion was as important then as now in determining what an owner would commission?
I've used running backstays short-tacking up the non-tidal Thames, racing in an A-rater. It's what the third man is for!
Although with many rigs you only need the runners down wind, as the leach tension does the job upwind.
No argument with any of that apart from the fact that raking the mast back creates a tripod effect with the shrouds and does in fact create more support than if the mast were vertical. You are still generalising. I didn't say all boats were the same. they are not. I have some experience of the Cape Cod schooners from which I believe the racing vessels like "America" were at least partly derived. Also there is a difference between an A-rater and a 220 tonne schooner. You need a bit more than a third hand at that size!!
