ferrispeterchris
Interested in a swing keel yacht (Newbridge Navigator) which is sitting on a trailer. Apart from using a crane has anyone found a way to raise one to inspect and work on the keel? Many thanks, Peter.
I know someone who is just having a new trailer built with modifications to allow dropping his Anderson 22 keel.
An important thing to bear in mind is to support the hull ( at the right places, ie under bulkheads ) when doing this, tiny standard trailer pads are not enough.
If he gets it right, he will have a superb and very useful trailer.
When I first got my boat, I thought the trailer was pretty ****. Mainly because it was in a poor state, two bearings were on their last legs, 2 tyres were perished and it was set up really badly.
Now it's been repaired and modified, it's much more useful and it now tows nicely. And with a fresh lick of paint (not shown in the photo) it looks quite reasonable.
Things have however moved on and "Hercules" is employed to do the lifting.
'swhat you want. Something like Hercules
Seen at the launching and naming ceremony earlier this year
That's a great way to name & launch a trailer - Now, what will you do for the boat? ;-)
The boat is Tony Curphey's Galenaia . Built 1958 but had been lying in Paynes Boatyard for many years before Tony took her on for his global voyaging.
http://www.cruisingclub.org/awards/awards_stephens_2008.htm
https://lh4.googleusercontent.com/-...X9hHo/s860/Tony%20Curphey%20summer%202011.jpg
I have heard of someone using a couple of railway sleepers, breize blocks and a couple of car jacks to do it but you take your life in your hands and depends how she sits on the trailer. You use two columns of blocks each end of each sleeper so you jack up on one each side and then insert a block on the other. YOu need the jack to be able to let you do 2 blocks so you can then lower the jack to put another on the jacking column.
I use a couple of Gantries at home. You would probably find it cheaper to hire a HAIB if you are not at a marina. If you are at a marina you will probably find they will only allow you to do certain things on their property due to H&S and insurance/liability.
