Radio problem
doug748
1 Oct 2002
UK. South West.
When I press to speak on my VHF it blanks the screen and does not transmit. The radio receives as normal and I have a feeling the set is not the problem.
Could it be power supply or maybe poor aerial connection?
William_H
28 Jul 2003
West Australia
As said power supply problem. Try a wire direct from battery positive to radio positive and likewise for negative. Make sure of course that battery is OK under load. Try lights etc. ol'will (probably bad in line fuse connections)
Refueler
13 Sep 2008
Far away from hooray henrys
Has anyone tried transmitting when antenna not connected ? That can fry the TX RF section and then that's it - radios for the bin. It will RX - but not TX ..
Worth trying the direct battery connection to see if its cabling problem ... but if its no good on 1W ... then likely naffed.
mikegunn
20 Aug 2007
I had a similar problem, intermittently. Radio worked fine on 1W but not always on max power. Returned set to Icom who found it to be free from fault. Discussed the perceived fault with an Icom engineer who suggested I re-examine my boat’s wiring and pay particular attention to the relevant fuse holder. He was spot-on! The fuse holder had relaxed its grip on the cartridge fuse, revealed by signs of arcing both on the fuse and the springclips. Replacement of the fuse holder cured the problem.
Mike
Roberto
20 Jul 2001
Lorient/Paris
sybrancaleone.blogspot.com
Specific
No, that may happen with non-marine radios, but technical specifications for maritime use approval require transmitting radios to be protected from both short circuit or antenna being absent.
Refueler
13 Sep 2008
OK .. but Radio Manuals still tell you NOT to do it ...
Here's Standard Horizon as example ... a regularly recc'd VHF Marine radio on these very Forums ...
