I went for a stern pole. Pros: easier to install and run cable; easier to access if needed; keeps weight a bit lower down; less sea clutter effect; easy to add other antennae (GPS, Navtex, etc); actually looks quite good (subjectively). Cons: more expensive than mast bracket; slightly reduced ultimate range (but more than enough range for normal use).
Same choice for pretty much the same reasons. Also makes taking the mast down much easier. I'm still not sure if there is an inline plug/socket for a Raytheon radar but I have never seen one. Also, on my boat the route for the cable inside the boat would be unsightly but unavoidable.
Now about to gain another advantage - the pole will partly support my new solar panel arch.
Which is more appropriate for a smaller boat and why is sea clutter less. What sort of range are you getting compared to the spec for your unit.
I have to confess I always thought the strut a better idea.
On a smaller boat you will need a disproportionately tall pushpit strut to raise the radome above head height. I worry a bit when I see boats with radar scanners mounted in such a way that a crew member can easily expose their body to direct irradiation. you will also be able to 'see' much farther with it up the mast a bit.
Not sure which is more appropriate for a smaller boat - it really depends on the size of the boat and the size of the radome.
As for sea clutter, this is caused by reflections from the sloping faces of waves. The higher the radar scanner, the more likely it is to pick up reflections from waves, especially close to the boat. You'll often find people saying that higher scanners result in less sea clutter, but the opposite is true. Commercial/naval ships have scanners mounted high to get range and to avoid reflections from structures on deck. For a leisure boat, a scanner on a stern pole is plenty high enough for adequate range and will result in less sea clutter effect.
Range does depend on height, but it's not that different. Mounted on a pole, say 12ft above sea level, the scanner would see the horizon at about 4 miles. On the mast, say at 35ft up, it would see the horizon at about 7 miles. Not a big difference. Naturally, the ability of the radar to see vessels beyond the horizon depends on their height. My radar has a theoretical range of 24 miles, but it's always used on much shorter settings.
[/ QUOTE ]An ordinary 6ft pole, deck-mounted, gives plenty of clearance in normal use. The radiation risk from a yacht radome is negligible - a typical 18" radome uses only 28W. Mast-mounting does increase range, but very little in practical terms.
I built a stern pole from reclaimed s/s and alu. I already had the mast strut, so I riveted that to my pole.
The pros for me are:
Much easier to run the cabling, and doesn't affect unstepping the mast
Weight lower down and less windage
A place for a spare vhf antenna
Handy place to fix eg throw line, deck brush etc
Easy access
Cons are slightly less range, and it's a bit ugly, but it will do until I build a stern arch one day
I would have thought there would be a blind sector where the mast is with a pole mounted scanner at the stern.
[/ QUOTE ]There is, but unless you put the scanner on top of the mast, there's a blind spot somewhere! With a normal mast mount, there's a blind spot astern. With a pole mount at the stern, there's a smaller (in angular terms) blind spot. The one which really amazes me is the radome mounted on the side of the mast (very popular on Hanse yachts for some reason) - in view of the mast profile, this must have a major blind spot.
Stern Pros: Somewhere for the Seagull to sit watching my binnacle instruments
It was cheap, as I had it made in stainless, which I was going to do anyway for the aerial arrays.
It contains my spare VHF antenna, my Navtex aerial and my GPS Aerial
It could be used to hoist my outboard up over the rail. (I use that block for a second flag staff)
It has a smaller blind spot going forward than the stern facing blind spot if it was on the mast.
It doesnt snag the Genoa on tacks
I could dismount and repair it in 10 minutes. Wiring easy to get at.
A smaller weight aloft
I does not swing through as much of an arc as one mounted 10m above the deck, so the total movement is smaller.
The wave clutter is lessened with a flatter horizon view plane
Stern Cons: Perhaps cheaper mast mount (but I dont think so)
Fried brains. Well no as mine is 2.7m above deck level
Less range, well mine is best at 12 miles anyway, so thats enough for a boat at walking pace. 24 miles its all a bit guessworky on a JRC1800.
I thinking of buying a furuno and mounting on the mast at low level 'underneath' the inner forestay. Will look a bit odd but well protected and well above head height. Will have to run the cable in duct outside the mast as it has polystyrene blocks inside.
We have a radome on a scanstrut about 2m above the cockpit seats. The radiation from yacht radars is very little hazard - dont stare straight at it from within a metre or so as your eyes are the most susceptible. Some good naval radar safety sites out there if you're worried.
For me, not fouling the headsail and avoiding the windage were significant considerations. We hoist the radar reflector up a shroud with a spare halyard when required for the same reason.
Personally I'd rather have the blind sector astern than forward.
FWIW some ships have at least 1 radar on top and usually the second in front of the mast, they will also have a large blind sector right astern on the lower scanner.
[/ QUOTE ]Yes, as I said, unless you put the scanner on top of the mast, there's a blind spot somewhere! But to put things into perspective, the "blind spot" on my boat represents an arc of only 1.3degrees. The only time this blind spot would be of real significance would be if I could maintain a steady course to within perhaps 1 degree. Usually, I can't! The blind spot astern from a mast mount would be somewhat wider.
