Radar – is it worth it on a 40 year old 30 footer?
I'm tempted to simply say that if you feel the need for radar then you should probably get it as something is clearly nagging at the back of your mind and nothing is guaranteed to spoil your sailing experience more than a feeling of vulnerability. Having said that overconfidence can be just as dangerous as ignorance so if by having radar you are likely to get yourself into situations that you would otherwise have avoided is it really enhancing safety on your vessel?
This is the central issue.
I suspect the OP's achilles heel is the fear of setting off due to imagined dangers, the radar is just another excuse to spend another season in a boatyard or within the Solent.
My advice is to cast off, clock up experience by heading to the CI in May when there is a good chance of fog. The radar fitting debate can be postponed until winter 18/19.
That is a rather large assumption and completely wrong, I was out of the Solent single handed within a few weeks of acquiring the boat in June - as soon as a few key things had been done, like fitting an autopilot and sorting out decent slab reefing. And have since been round the island, down to Swanage etc. Not lengthy trips as I have not had the time, but each one testing out something. Apart from short trips I'll be off single handed to the west country in May, and if the weather gods are very kind possibly even the Scillies.
I started sailing round the CI over 40 years ago without any significant electronic aids - that is when I wasn't too busy with RORC races, ton cups, Coaching and other things.
If, as is likely, the radar thing happen (probable sourcing of a second hand scanstrut helping to ease the decision) it will be done and dusted by the end of January.
Perhaps you are projecting your own problems on to others.
If you do go for radar, my logic (at the time I fitted mine) was why spend a pot of money on kit that only works properly if one is upright most of the time (ship or motorboat), rather than pointing down to the depths and up to sky (as a fixed radome would spend a lot of time doing on a yacht's mast)?!
So I bought the Scanstrut gimbal unit designed to fit the front of a mast, but as I wanted it on a stern-pole I got a local fabricator to run me up a simple, inexpensive custom s/s pole which clamps to the top pushpit rail and has a flange that bolts to the aft cockpit seat. The diameter of the top bit is wider than the rest of the pole to simulate a mast section so the 'claw' bolts on correctly (from memory 3" diameter to pole's 2"). All much cheaper than Scanstrut's pole or backstay offerings. My guy even welded on 'eyes' so I could brace the pole if necessary, but this has so far proved unnecessary even in rough seas.
It looks that that is going to be shining right at the crew when the boat is well heeled to starboard.
The photo is deceptive, the pole is high enough. Even at extreme angles of heel (which my Vancouver 27 simply refuses to do), the death-rays will only ever strike a crew hanging about on top of the coach-roof, which he/she/it has no business doing while we're in 'radar conditions'. Down in the cockpit or even standing up in the companionway its well clear. :)
Don't undersestimate the vertical beamwidth of a typical yacht radar. 25 to 30 degrees to 3dB ( half power ).
yes, looks a decently high pole and on a small boat (no offence intended!) with a short cockpit the angles look good. And as you imply, best to shut down when people are forward.
P.S. I see we are both C.A. Members :)
Look on the bright side, it may have stopped him breeding already.
Charming, a Happy New Year to you too.
There still isn't any evidence that cruising yacht radar can cause illness though. Nada. Zilch. Sweet Fanny Adams. That's because it's harmless.
Keeping an effective radar watch without another person on watch is really quite hard. Having the display below decks doesn't help, but having it on deck is not great in rain and weather either. There are times when a yacht with a pilot house suddenly seems like the obvious answer you've been missing.
I can only agree about the need for display to be visible to the helm if at all possible. For instance I am appalled that some boats seem to have depth gauges and chart platters below deck. Do they only ever navigate in close quarters with an extra crew member on watch permanently at the navigation station below deck? I have built a semi-pilothouse and so can readily mount more displays there, but most marine kit is weatherproof enough to be mounted under the sprayhood at least, and swingout mountings by the washboards are also possible if a bit intrusive when going between cabin and cockpit.
We each have different ways of managing our sailing, and different boats lend themselves to different approaches, so there is little point in trying to lay down the law for operating procedures.
Indeed.
Sometimes even on a two person racing dinghy, there is much to be said for the helm sailing the boat while the 'crew' gathers the info and even makes many of the decisions.
Not everybody is a singlehander and not all singlehanders man the helm constantly.
There are boats with the converse problem, where only the person steering has proper access to the displays. I find that worse, personally.
