julians
So this is a bit of an odd problem, wondering if the assembled experts have any ideas?
The windlass in question is a Quick bl2 windlass,it is just over one year old, as is the boat it is fitted to. All contacts and connectors are clean and free of corrosion
The windlass will lift and deploy the anchor absolutely fine, paying out (with one exception see further on) and pulling in chain with no issues at all, even when under significant strain,it runs cleanly and quickly.
However it trips the circuit breaker upon the first attempted deployment (not retrieval ) of the anchor of each day, ie the anchor is safely stowed on the roller, you get to your preferred bay for the day, press the down button (and I am pressing the down button,it's not the up button by mistake) to deploy the anchor,but the anchor doesn't deploy, you hear the motor attempt to turn,but there is no movement at all from it,it is as if it is jammed. At this point the circuit breaker trips, so you reset it,then press the windlass down button again,this time the motor runs fine, the anchor deploys fine, and can then be retrieved and redeployed as many times as you like with no tripping,until the next day when it trips again on the first deployment.
It's very odd,it's like the motor or mechnism is jammed up,or like you're pressing the up button,but I assure you I'm pressing the correct button.
The manual doesn't have much troubleshooting info in it.
Any suggestions?
Any suggestions?
