Question re galvanic corrosion
citygent111
11 Oct 2021
Hi all, please could someone explain this to me?! I have a 19ft boat at Conwy Marina (so saltwater), but she is not connected to mains electricity. I fitted a new set of anodes in March. Am I likely to need new anodes when she's lifted for winter?
I've tried to get my head round the whole corrosion thing, but chemistry was never my strong point, and my last lesson was almost 40 years ago!
Tranona
10 Nov 2007
Depends on what they are protecting. You don't say what sort of boat it is, but an anode is normally used to protect a propeller from the shaft on a shaft drive boat or on a sterndrive motor boat the drive housing from the shaft.
If the former then usually a hull mounted anode will last more than a year, an anode on the shaft a shorter time (because it is smaller) and the latter type also shorter time. you will only know if they need replacing when you lift the boat so plenty of time to get new ones if needed before you launch.
rogerthebodger
3 Nov 2001
For galvanic corrosion to take place you need 4 things.
2 dissimilar metals immersed in an electrolyte Isea water) and an electrical connection between the dissimilar metals
If any one is missing you generally not experience galvanic corrosion.
The questions by vyv_cox and Tranona are the ones you need to answer first
My boat is steel, and I looked into galvanic corrosion extensively so to protect my steel boat from galvanic corrosion
wonkywinch
30 Jul 2018
Hamble, UK
Did you ever make a potato battery at school? Our boat seems to want to continue that experiment in the marina despite fitting a galvanic isolator and more recently not using shore power as a habit.
citygent111
11 Oct 2021
Ok a bit more info too - it's a 19ft Fletcher speedboat effectively. GRP/Firbreglass hull. Mercruiser inboard engine with Alpha 1 drive. The anodes are the standard kit supplied, so one goes behind the prop, then one near the skeg and a couple a bit higher up (been 6 months since I've seen them!)
Alex_Blackwood
19 May 2003
Fareham
You will know when you see them again, seriously almost impossible to tell until then.
trapper guy
15 Mar 2024
as i understand things in terms of chemistry, galvanic corrosion doesnt even need an electricity supply, as the positive and negative ions in the metals produce their own supply, all it needs is an electrolyte, which can be as simple as moisture in the air.
when typical air contains as much or more than 80% moisture, corrosion will occur regardless.
in terms of attachment to masts, for such things as steps, i often hear the arguments of what fittings are best, there is a simple answer to every such question and that is, the fixings should be, as far as possible, the same kind of metal. so for steps i would opt for aluminium steps and aluminium rivets, as from what can be seen on this chart, pretty much everything bar aluminium will react with aluminium.
sure, you can get zinc plated screws, but plating i only good for so long, and the action of inserting them can scratch the plating through to parent metal.
https://www.simpletwig.com/blog/wp-content/uploads/2017/05/GalvanicActionChart.png
trapper guy
15 Mar 2024
there is no anode in the engines sea water cooling supply??
vyv_cox
France, sailing Aegean Sea.
coxeng.co.uk
Galvanic corrosion never depends upon an external electricity supply. Electrolytic corrosion occurs when there is an external supply.
