Miken
My Boat has a service battery and Starting Battery wired via a VSR cluster so the Starting Battry Charges first then cuts over to the Service battery when the Starting Battery has reached it's charged voltage.
Over the Winter I have installed Shore Power and have a Mains Charger that can support two battry bank connections.
The Question is
Is it better to wire the charger via it's primary output to the VSR Cluster and let the VSR split the Charge to each Battery or run seperate charge lines from both charger outputs direct to each Battery.
The Question is
