Bosun Higgs
N/A
By now the Volvo 2002 will be getting on a bit. You can expect some smoke on start up and that will also put a film of diesel on the water. No problem. Let the engine idle when warm and then does it belch smoke when you rev up - thats a sign of some wear in the bores ( pistons cooling down at idle and letting some lube oil past the rings). Mine did that but is still in use 5 years later.
Guard against expecting a second hand boat to be new - it isnt. So you arent buying perfection and wont get it. Issues like rig tuning are trivial. If you didnt have quite a few jobs on the list after purchase it would be a miracle.
