Bigplumbs
Nice Subject this but someone gotta do it
On our Sealine on the Norfolk Broads (which has a holding tank and switch over valve) it is not good to pump your poo into the river as many do at sea (and many on the broads for that matter!) We don't use our boat that much on the broads so it only needs a pump out once in a very long while. It is also a 2 hour plod in the boat to the easiest pump out station that is I think £20. Also it is an issue not really knowing how full your tank is. I know you can fit a gauge which ours has but it don't work. I was wondering if in these circumstances you are actually better off with a cassette bog rather like in our Motor home and Caravan. Then I thought DIY.
So here is the question. Does anyone know of a DIY Solution with perhaps a 10 gallon can and a pump that would fit the deck fitting. This way you can pump out the tank yourself responsibly ever say 3 uses of the boat. Take it home and either sell it on ebay
or some other better method of disposal ?
