aerobat
Hello gents !
I,m new here and first a hello to everybody !
Now my issue and questions to you , sorry for a long story :
I signed a contract on a 2000 gobbi375sc in winter with boat stored on land with a written declaration of the seller that should any hull or technical issues be found during the survey in spring it will be fixed on the sellers costs .
The survey found osmosis on the hull .
After first shock and thoughts to run - after extensive talks with a specialized yard on fixing osmosis - they convinced me not to panic . After a very detailed hull survey of this yard They say the entire underwater hull needs to be sanded and grinded up to the laminate , then dry out with warm forced air until acceptable moisture levels will be reached , the a special watertight epoxy - osmosis protection cover ,then several layers of primes and new antifouling .
They give 7 years warranty and swear the hull will be better than new . The costs are breaking the bank but since the seller signed a contract , tried to hide the osmosis its his call not mine and he agreed to pay .
Now , the seller close to cardiac arrest , the yard calls for removing the transom shields simce osmosis was also found close to the transoms.
this means to pull both engines .
The engines are KAD44 EDC
I made sure that this will be also done by A certified yard with warranty and of course also on his costs but i,m afraid we open a can of worms what surprizes will come anf if all will be done properly since its a major work .
Should we go this path - what to expect to be checked when the engines and transom shields go out ? The engines and drives were fully serviced last spring by a volvo penta dealer , new bellows , filters , oil , belts , valve clearance etc .
Steering pins ? Of course i will use the chance for cleaning the heat exchangers , aftercoolers , checking the turbos etc .
Any more ideas ? engine are verified 950 hours , first owner and verified freshwater sitting boat with occasional trips in salt .
thanks for any hints and thoughts .
Best regards !
Best regards !
