Pulling the sticks - what will it entail?
CharlesM
9 Mar 2004
UK
Hello all
Could anyone give me an idea of what would be involved, and the skills required to take down the masts of a 43' ketch for storage for lets say 6 months?
Charles
graham
I think for a boat of that size you will be requiring the proffessional services of a boat yard.
If you can get a crane alongside it would be feasible to do a DIY job if you have some experience in that type of thing and then somewhere to store them.The obvious place is usually on or under the boat if ashore.You need to construct some supports to lay the spars on .Headsail Roller reefing spars are vulnerable to damage if mishandled.
VicS
13 Jul 2002
A crane with an operator who is used to this sort of thing.
You don't say where you are. Perhaps a bit of an overkill for a mast but for anyone along the south coast in the solent area who needs a boat lifted MEON VALLEY CRANE HIRE. A one man operation who is absolutely ace with boats. Sorry I don't know his max capacity but he does them up to 32ft at the yard I operate from.
Thistle
2 Oct 2004
Here
Easy job with a boatyard crane and experienced / insured operator. Probably around 15-20 minutes per mast. Well worth the few tens of quid you're likely to be charged.
Given the size and weight of the masts and the potential for damage to the masts, your boat and others round it, and to the people involved I don't see it as a DIY job at all.
Most yards will have an out-of-the-way area where masts can be stored, often with suitable trestles already in place.
fireball
15 Nov 2004
I protected the genoa furler track by strapping it down the length of the mast with sail ties and then removed the drum so it didn't dangle and put more stress on the foil.
CharlesM
9 Mar 2004
UK
Thanks All
I will certainly have it done by the boatyard. It will be part of the pre-hurricane season preperation for stowing the boat.
I just wanted to get an idea of what was involved.
Later
Charles
kandoma
19 Dec 2004
Switzerland
in an emergency, you can do it yourself. Use the "Japanese method". Rigg a second stick (can be wood) just in front of the mast. The length of the stick has to be slighly more then 50% of your mast. You can construct a wooden shoe to protect your deck and keeping the stick from moving. Put up some temporary stays, to keep the stick up. Then use a 4:1 (mhmm how do you call this in english)
and lower the mast. Thats how it is done in Japan when a Taifun is coming. I have seen them doing it with boats bigger then 43 feet, but always the boat was resting on land. I would not try this method in the water myself. Otherwise, it looked quite safe.
Peter
LittleShip
21 Jul 2003
In the water .... most of the year!!
My boat yard charge £50 to step the mast, quite cheap when you concider the damage that it would cause if "you" drop it?? Let the professionals do it.
Ahemm ! that dosent sound like me, but there are some jobs that are not worth the risk??????? /forums/images/graemlins/smirk.gif
