PSS Seal - advice please
ex-Gladys
29 Aug 2003
Colchester, Essex
Whilst out for the first sail yesterday, was busy trying to track down a diesel leak when I literally touched the bellws on the PSS and a lump of water came in - maybe no more than 100cc, but enough to give me a jolt. Are these things that sensitive to touch?
It dripped after it reseated, but a quick session in ahead soon lined things up again.
<hr width=100% size=1>Larry Botheras
Anderson 26 "Amber"
Yes they are,but you should check that you have enough compression on the seal.There should be a gauge of some kind or at least you should know what length the seal should have when correctly set.
It's a bit of a b**ger to check, but the bellows look well compressed. It is 10 years old.... Perhaps time for a new one?
Anderson 26 "Amber"
ours is a high speed rather than the conventional low speed. Water pipe is cut off above LWL so it self bleeds.
Anderson 26 "Amber"
