William_H
Sail to keel balance
Searush. I hate to be argumentive however.... That never stopped anyone. Firstly CLR Centre of Lateral resistance. Lateral as in sideways pressure.
My opinion is that this theory of balance is much over rated. Most boats will sail happily under main sail alone or jib alone. One huge mismatch of CLR to CE.
Yes I know I have done exercises where using the balance of jib versus main provides the only steering to the boat on a reach but even then the turning force is not great.
I have seen a lot of boats where mast position is adjustable. The owners have not really come to any significant conclusions. Almost always they are trying to minimise weather helm coming from excessive heel.
So I would suggest that OP not worry too much about mast position. A comparison to other boats will show what is reasonable. Certainly for a fractional rig with small jib mast forward while a mast head rig big jib mast back. But even those only in the range of max 9 inches between the 2.
Boom length is dictated by mainsail size (that you get SH) clearance of backstay and again what is reasonable. Bigger = light wind performance shorter= better handling in stronger winds.
As already said performance is good for cruising as well as racing. It can mean you can conservatively reef and still go really well to windward. A poor performing boat will be a real pain if windward is the only way home and you have had enough sailing. (Hence my aversion to roll up jib reefing.)
olewill
olewill
