Searush
FFS! Start with the hull you have. If built from drawings there will be rig details included. Change them at your peril if are not expert.
There should be a pad on the coachroof where the mast is meant to go, there should also be strong point at the bow & at each side of the hull exactly in line with where the mast goes and another (possibly two) at the stern. They will define the basic fixing points for your rig - again THESE MUST NOT BE CHANGED unless you are an expert.
If you have no drawings, you can use these dimensions to help you select possible used rigs. BUT, you have to get the balance right between the jib & main if using Bermudian, so you will need to research & understand rig design. Even if you get something close, you will need to identify lee & weather helm & know how to correct them.
You still haven't said what her keel design or ballast ratio is & they can have a big impact on the rig design. An outboard could cost you 4k, the rig another 4 plus another 4k for sails & fittings. Your budget is extremely tight.
